Re: Car steering wheel in a truck?
[Re: GOT6PAK]
#2401531
11/10/17 07:32 PM
11/10/17 07:32 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
That's so weird because they say in their add that it fits E body and A body along with C body lol... I think the wheels are more year specific than car line specific. The big difference I see is the key in dash compared to key in column. Not sure just what you are wanting to put this wheel on, but I put a stock '66 Coronete wheel on my 77 B-200 van. It physically fit, (i.e. The splines were the same), but was a tad shy on the outside diameter of the wheel and the open ended column was visible around the outside circumference of the wheel. I also have a '70s aftermarket wheel that I took off a '69 Dart in the '80's currently on my '76 D-200 pickup. The splines match up and adapter cover on that looks and works just fine.
I have mechanical Aptitude. I can screw up anything.
[Re: 71birdJ68]
#2401552
11/10/17 08:12 PM
11/10/17 08:12 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Don't know which wheel you're looking at , but my 84 Ram had a very good looking Tuff wheel from the factory. I had 4 spokes instead of the 3 like the cars had, and was a tilt column. They look pretty good in an e-body to boot. Those 84 tilt column wheels are probably the best looking wheel Ma ever made in my opinion.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: GOT6PAK]
#2401555
11/10/17 08:15 PM
11/10/17 08:15 PM
bboogieart
Lost and Spaced
Your link does not work. This wheel comes with the adapter, horn button etc...It's a kit. Here's the link. https://www.classicindustries.com/product/*mw99602a.html The link posted by " DarrenS" shows the adapter I have on my '76 D-200 truck with an after market wheel I took off a '69 Dart. It states it is for the 60's. The other wheel that was on my '77 van was factory stock off a '66 B body, these all had the same spline. I also had the wheel currently in my 76 truck in the 77 van at one time. I hope this is what you are looking for.
[Re: GOT6PAK]
#2401591
11/10/17 09:35 PM
11/10/17 09:35 PM
Posts: 1,357 central Florida
VL21
central Florida
Confused yet?
I believe the wheel you are looking at will fit the 75 key in column truck just fine.
The main differences I have found are between tilt and standard columns, the spline for all the interchanges I have attempted have worked out straight column to straight column, no problem.
For instance, I have used the 4 spoke Omni/Horizon rubber rim wheel in both my '85 and a previous 93 D150.
Tilt to tilt, to problem.
AND, I am pretty sure the tilt columns have the same spline as GM vehicles, as I am pretty sure the tilt columns are built by Saginaw.
I suppose I could be wrong, I DID get married once ...
It takes gasoline to interest me.
[Re: VL21]
#2401759
11/11/17 03:47 AM
11/11/17 03:47 AM
Posts: 891 Southern California
GOT6PAK
Southern California
Confused yet?
Yes I am lol... I wish Classic Industries would show a better picture of the adapter that comes in that kit. You can barely see the adapter in their add but who knows if that's the actual picture of what you're getting. I guess I need someone who has bought this kit to send a picture of their install.
[Re: Ramtough]
#2401880
11/11/17 01:33 PM
11/11/17 01:33 PM
Posts: 19,396 north of coder
moparx
70 and newer mopars have 2 different splines that I'm aware of B and E Body use one and A Body and truck use another 69 and older have the same spline as 70 and up, but the column diameter on the 70 and up is a lot larger due to the key in the column. this requires a larger adapter "can" to cover the column internals. i installed a small diameter C body wheel on my 74 D100, and it fit perfectly. i also installed said wheel [one identical to it] on a 72 sattelite. same great fit. splines are the same as had been mentioned between column types, straight to straight, and saginaw tilt/tilt-tele columns. 69 charger wheel to 64 barracuda [straight columns], 64 barracuda to 48 plymouth [!], same spline, but the 48 column diameter was way smaller than the 64 barracuda, necessitating a custom fabbed cover. just some of the many swaps i have preformed in over 50 years of playing with these things.
