Too much seat pressure ?
#2401255
11/10/17 02:59 AM
11/10/17 02:59 AM
Posts: 2,628 Middle TN
da50r
Middle TN
On an average... how much pressure is too much seat and open pressure for a mild hyd flat tappet street cam? Say basically a 340 cam or a touch warmer cam. Slightly higher ramp speed but basically a 340 cam? Just curious what a 5,800 rpm street engine spring pressure should be? I don’t see a need to wipe a cam but also don’t want to float the valves at 5,300 either. Thanks guys.
360/ X heads 9:1 compression HP manifolds.
Re: Too much seat pressure ?
[Re: da50r]
#2401267
11/10/17 03:28 AM
11/10/17 03:28 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I would always go by the cam manufacturers spring recommendations. No way to know requirements based on sound of cam or looking at lobes. My 2💰
[Re: da50r]
#2401272
11/10/17 04:00 AM
11/10/17 04:00 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
What type(stock or anti pump up) and brand of lifters are you going to use and what type of rocker gear and pushrods?
[Re: da50r]
#2401368
11/10/17 01:12 PM
11/10/17 01:12 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Pick a cam/lifter/rocker combo.......then decide on the appropriate springs.
