#2398474 - 11/04/17 04:31 PM 1986 250 4wd rear shackle rotted out
pontiac58 Offline
Loc: vineland nj
Like the subject says the left rear shackle rotted out on my truck. Looked around the net but everything says it doesn't fit. There has to be one being made out there. Any one have some info on this. I can get my hands on used easy just don't want to put one on that is already half gone.
Im a jeep nut with a dodge truck to drag the jeep home after a weekend on the trails.
#2398522 - 11/04/17 06:11 PM Re: 1986 250 4wd rear shackle rotted out [Re: pontiac58]
ruderunner Offline
Loc: ohio
The actual shackle or the bracket riveted to the frame?
Either way you'll need to know what size bolts are in there, could be 1/2", 5/8", or possibly 3/4"
I've modified F-150 parts for one truck and ranger shackles for another.
#2398547 - 11/04/17 07:25 PM Re: 1986 250 4wd rear shackle rotted out [Re: pontiac58]
jerseybud Offline
Loc: Maine
rence should be bolt hole size. Buy the 1/2 inch one and drill the hole to 5/8 or 3/4, which are your only options
http://www.sdtrucksprings.com/index.php?...AyABEgJD7fD_BwE
#2399261 - 11/06/17 08:19 AM Re: 1986 250 4wd rear shackle rotted out [Re: jerseybud]
scratchnfotraction Offline
Loc: Florida
I may have a shackle you can have. if its the shackle piece you need.
don't have the frame hanger.
PM here me if needed.
scratch
#2400160 - 11/07/17 06:00 PM Re: 1986 250 4wd rear shackle rotted out [Re: pontiac58]
pontiac58 Offline
Loc: vineland nj
thanks everyone haven't had a chance to measure the bolt yet. Ill be over by it tomorrow. Left at a friends junkyard to fix it there.
25,149 Registered Members
186,793 Topics
Found my new truck and totally affordable...
by Guitar Jones
02/23/18 05:26 PM
Polar Bear Jaws
by amxautox
02/23/18 04:38 PM
Fiddy six Coronet
by Neil
02/23/18 03:42 PM
1977 Dodge Maxi van
by FM3_1970
02/23/18 01:52 PM
