1986 250 4wd rear shackle rotted out #2398474
11/04/17 06:31 PM
11/04/17 06:31 PM
vineland nj
P
pontiac58 Offline OP
P
vineland nj
Like the subject says the left rear shackle rotted out on my truck. Looked around the net but everything says it doesn't fit. There has to be one being made out there. Any one have some info on this. I can get my hands on used easy just don't want to put one on that is already half gone.
Im a jeep nut with a dodge truck to drag the jeep home after a weekend on the trails.
Re: 1986 250 4wd rear shackle rotted out [Re: pontiac58] #2398522
11/04/17 08:11 PM
11/04/17 08:11 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
The actual shackle or the bracket riveted to the frame?
Either way you'll need to know what size bolts are in there, could be 1/2", 5/8", or possibly 3/4"
I've modified F-150 parts for one truck and ranger shackles for another.
Angry white pureblood male
Re: 1986 250 4wd rear shackle rotted out [Re: pontiac58] #2398547
11/04/17 09:25 PM
11/04/17 09:25 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
rence should be bolt hole size. Buy the 1/2 inch one and drill the hole to 5/8 or 3/4, which are your only options
http://www.sdtrucksprings.com/index.php?...AyABEgJD7fD_BwE
Re: 1986 250 4wd rear shackle rotted out [Re: jerseybud] #2399261
11/06/17 11:19 AM
11/06/17 11:19 AM
scratchnfotraction Offline
I may have a shackle you can have. if its the shackle piece you need.
don't have the frame hanger.
PM here me if needed.
scratch
Re: 1986 250 4wd rear shackle rotted out [Re: pontiac58] #2400160
11/07/17 09:00 PM
11/07/17 09:00 PM
vineland nj
P
P
vineland nj
thanks everyone haven't had a chance to measure the bolt yet. Ill be over by it tomorrow. Left at a friends junkyard to fix it there.
