440 aluminum water pump and housing #2399694
11/06/17 11:35 PM
11/06/17 11:35 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Looking for an aluminum housing (output on the drivers side) and high vol pump for the 440. I've seen some older posts about the stuff from 440Source, any improvement there? The pricing is good. Mancini and MP packages also look good, a bit more money. Anyone have any info on any of these, fit, quality, performance, etc? Thanks.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 440 aluminum water pump and housing [Re: busboy] #2399705
11/06/17 11:56 PM
11/06/17 11:56 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Buy the Mopar one
2011 Drag Pak Challenger
Re: 440 aluminum water pump and housing [Re: rickseeman] #2399710
11/07/17 12:05 AM
11/07/17 12:05 AM
busboy Offline OP
busboy  Offline OP
Thanks Rick, what do you like about them?
Re: 440 aluminum water pump and housing [Re: rickseeman] #2399714
11/07/17 12:09 AM
11/07/17 12:09 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
440 Source Housing and Milodon water Pump. Used this combo on a few engines with no Problems.
The only Carbs I care about are under the hood!
Re: 440 aluminum water pump and housing [Re: busboy] #2399726
11/07/17 12:20 AM
11/07/17 12:20 AM
busboy Offline OP
busboy  Offline OP
Thanks cuda, no issues with the pump depth using the milodon in the Source housing then?
Re: 440 aluminum water pump and housing [Re: busboy] #2400029
11/07/17 05:05 PM
11/07/17 05:05 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've been using the driver side 440 source housing and pump for 7-8 years without any issues. I also have a pass side housing and pump I bought 2 years ago and no issues there either.
Re: 440 aluminum water pump and housing [Re: busboy] #2400055
11/07/17 05:42 PM
11/07/17 05:42 PM
BlueRacer69 Offline
BlueRacer69  Offline
I have the Mopar alum housing and Milodon high performance water pump on my 69 440. They seem to work well together. Don't forget about getting a good high flow stat also to round out your combo.
Re: 440 aluminum water pump and housing [Re: BlueRacer69] #2400217
11/07/17 10:27 PM
11/07/17 10:27 PM
IN
ahy Offline
ahy  Offline
IN
I run the MP housing and high volume pump with anti cavitation plate... purchased a while ago. The combo works great. The MP pump has gotten very expensive or not available. Done again, I would go with the Mancini setup.
As far as the housing... there may be differences but I do not think the outlet size is an issue now with the 440 Source offering.
On pumps, there are differences that matter. The simple vane type pump with anti-cav plate run at least a little faster than crank speed works well for me (and others). The sexy scroll type pumps not so much from what I have seen.
