rear main leaks #2399023
11/05/17 08:12 PM
11/05/17 08:12 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
it doesn,t leak. ran the 470 for about a half hour , no leaks! heading out to dinner now, details to follow.
Re: rear main leaks [Re: eds dart] #2399253
11/06/17 11:06 AM
11/06/17 11:06 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
boogie
laugh2
Re: rear main leaks [Re: eds dart] #2399302
11/06/17 12:54 PM
11/06/17 12:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Cool! Glad to here somebodys don't. I noticed the other day I have a few drips under mine. I can live with it. could be worse.
Re: rear main leaks [Re: eds dart] #2399317
11/06/17 01:21 PM
11/06/17 01:21 PM
I'm assuming you're picking up the tab!
Re: rear main leaks [Re: eds dart] #2399421
11/06/17 04:02 PM
11/06/17 04:02 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
identified some issues with the seals. the non fel-pro seals I was using had a small protrusion adjacent to the seal area. I called the company involved and talked to a tech guy, sent him some pictures . haven't heard back yet. also the billet retainer I used had a couple contac points with the #5 cap. also milled some clearance for the main stud nuts and milled a relief channel for the oil to escape. the stock retainer has lots of clearance to all the cap and such, the billet retainers are flat and tight to the main. having said all that I cant pinpoint where the problem was or what the actual fix is. also the #5 studs need shortened, they will hold the windage tray up a slight amount. picked up the whole tab also.
