Re: 5.7 and the 727 pb
[Re: hudsonhornet7x]
#2399513
11/06/17 06:57 PM
11/06/17 06:57 PM
Posts: 183 usa
csmopar
usa
It will bolt right up. You just need the correct flex plate. Sweet thanks
[Re: sam64]
#2399514
11/06/17 06:57 PM
11/06/17 06:57 PM
Posts: 183 usa
csmopar
usa
if it is pre 1965 I think the bottom pass.bolt will not line up,other than that it will work. It's a 64
[Re: csmopar]
#2399550
11/06/17 07:55 PM
11/06/17 07:55 PM
moparpollack
Lil Herman
Lil Herman
85086
Are the bolts that go into the block metric?
[Re: savoy64]
#2399645
11/06/17 10:20 PM
11/06/17 10:20 PM
Posts: 153 MI, USA
moparmitch
MI, USA
you also need that thin spacer that goes to the block---or there is a new torque converter being made to allow for that thickness.... What's the thickness? I assume a mid-plate could take care of this?
[Re: sam64]
#2399901
11/07/17 12:24 PM
11/07/17 12:24 PM
Posts: 183 usa
csmopar
usa
[Re: csmopar]
#2400154
11/07/17 08:51 PM
11/07/17 08:51 PM
Posts: 2,042 colorado
savoy64
colorado
the spacer looks like 3/64? and is used on the 5.7 and the 4.7-----a friend has done 4 of these into older mopars and has bought these off ebay i believe----i grabbed a junkyard one for him and he announced he got a torque converter that was made to delete the need for that spacer....someone here must be up on it......mopar part number 53032454AA.
