5.7 and the 727 pb #2399320
11/06/17 01:30 PM
11/06/17 01:30 PM
usa
csmopar Offline OP
csmopar  Offline OP
usa
I've been trying to determine if a 5.7 hemi can mate to a small block 727 pushbutton. Has anyone tried this?
Re: 5.7 and the 727 pb [Re: csmopar] #2399391
11/06/17 03:09 PM
11/06/17 03:09 PM
USA
hudsonhornet7x Offline
USA
It will bolt right up. You just need the correct flex plate.
Re: 5.7 and the 727 pb [Re: hudsonhornet7x] #2399504
11/06/17 06:40 PM
11/06/17 06:40 PM
okla.
sam64 Offline
sam64  Offline
okla.
if it is pre 1965 I think the bottom pass.bolt will not line up,other than that it will work.
Re: 5.7 and the 727 pb [Re: hudsonhornet7x] #2399513
11/06/17 06:57 PM
11/06/17 06:57 PM
usa
csmopar Offline OP
csmopar  Offline OP
usa
Sweet thanks
Re: 5.7 and the 727 pb [Re: sam64] #2399514
11/06/17 06:57 PM
11/06/17 06:57 PM
usa
csmopar Offline OP
csmopar  Offline OP
usa
It's a 64
Re: 5.7 and the 727 pb [Re: csmopar] #2399550
11/06/17 07:55 PM
11/06/17 07:55 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Are the bolts that go into the block metric?
Re: 5.7 and the 727 pb [Re: csmopar] #2399624
11/06/17 10:01 PM
11/06/17 10:01 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
No, 3/8-16 thread I used the small block ARP bellhousing bolt kit
Re: 5.7 and the 727 pb [Re: csmopar] #2399625
11/06/17 10:01 PM
11/06/17 10:01 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
you also need that thin spacer that goes to the block---or there is a new torque converter being made to allow for that thickness....
Re: 5.7 and the 727 pb [Re: savoy64] #2399645
11/06/17 10:20 PM
11/06/17 10:20 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
What's the thickness? I assume a mid-plate could take care of this?
Re: 5.7 and the 727 pb [Re: csmopar] #2399654
11/06/17 10:33 PM
11/06/17 10:33 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Doesn't the right flex plate eliminate the need for any spacers?
Re: 5.7 and the 727 pb [Re: cudadoug] #2399670
11/06/17 10:57 PM
11/06/17 10:57 PM
okla.
sam64 Offline
sam64  Offline
okla.
some of the first flex plate conversions used a spacer between the block and trans.because the flex plate was flat.
Re: 5.7 and the 727 pb [Re: sam64] #2399901
11/07/17 12:24 PM
11/07/17 12:24 PM
usa
csmopar Offline OP
csmopar  Offline OP
usa
awesome thanks
Re: 5.7 and the 727 pb [Re: csmopar] #2400154
11/07/17 08:51 PM
11/07/17 08:51 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the spacer looks like 3/64? and is used on the 5.7 and the 4.7-----a friend has done 4 of these into older mopars and has bought these off ebay i believe----i grabbed a junkyard one for him and he announced he got a torque converter that was made to delete the need for that spacer....someone here must be up on it......mopar part number 53032454AA.
Re: 5.7 and the 727 pb [Re: csmopar] #2402449
11/12/17 01:09 PM
11/12/17 01:09 PM
Ohio
C_B5 Offline
C_B5  Offline
Ohio
Related question - Are you planning to retain the pushbuttons to shift the trans ?
I would be interested in knowing what cable set-up you're using to connect the pushbutton to the trans.
