1970 Fury brake booster help #2399227
11/06/17 10:23 AM
11/06/17 10:23 AM
UK
Z
Zephyr Offline OP
Zephyr  Offline OP
Z
UK
I'm restoring a 1970 Plymouth Fury III convertible and I definitely need to overhaul or replace the brake booster. The internet tells me I need one of these: http://www.cardone.com/Products/Product-Detail?productId=54-73500, but it's completely wrong.
I think I may have a Midland Ross item. It has a metal tag with the following numbers: 2944041 73608 3469-A and C-4219-G. It attaches via a bracket and there's a linkage between the pedal and the rod that sticks out of the back of the booster.
[img]https://www.forcbodiesonly.com/mopar-forum/attachments/20170616_163741-jpg.128756/[/img]
I'm in the UK, which doesn't help. Anyone recommend a supplier of rebuild kits or replacement boosters?
Re: 1970 Fury brake booster help [Re: Zephyr] #2399279
11/06/17 12:05 PM
11/06/17 12:05 PM
Zephyr welcome here. I dont have a recommendation but I would start by seeing if there are any brake work sponsors in our sponsor listing section & you might Google it also.
Re: 1970 Fury brake booster help [Re: Zephyr] #2399314
11/06/17 01:17 PM
11/06/17 01:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Is it power drum or power disc?
I have power drums on my '70 Fury if you need a photo of my booster.
Re: 1970 Fury brake booster help [Re: Alaskan_TA] #2399383
11/06/17 02:47 PM
11/06/17 02:47 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
That is indeed a Midland Ross booster. They came gold cadmium plated when new. The Midland Ross are identifiable by the case being held together by a large clamp. Google "Booster Dewey". He is in Oregon, USA. He will rebuild it to be good as new, and can send the case out to get replated as well. Very reasonable prices too.
Re: 1970 Fury brake booster help [Re: Zephyr] #2399452
11/06/17 05:19 PM
11/06/17 05:19 PM
UK
Z
Zephyr Offline OP
Zephyr  Offline OP
Z
UK
It's drums all round.
