Manley NexTek Valve Springs #2399068
11/05/17 09:49 PM
11/05/17 09:49 PM
Affton MO
Q
qwkmopardan Offline OP
Q
Affton MO
What is the differance in polished and non-polished springs. Polished over $200 more cash. All the installed heights are the same, pressures same at all listed heights. Longer life??? Worth the extra $200??
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2399086
11/05/17 10:16 PM
11/05/17 10:16 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Polishing springs is like stress relief. Removes any imperfections that can cause fractures.
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2399092
11/05/17 10:23 PM
11/05/17 10:23 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Removes SURFACE imperfections/stress risers. That does NOT protect from inclusions inside the wire. They seem to have had a good track record for quality last time I checked but, I would do a quick internet search. Personally I wouldn't pay the extra money for this process.
Re: Manley NexTek Valve Springs [Re: HardcoreB] #2399206
11/06/17 04:46 AM
11/06/17 04:46 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree That's $200 toward another set.
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2399358
11/06/17 02:13 PM
11/06/17 02:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I ran Manley Nexteks for a very long time on the Cuda. Never went with the polished ones and yes I know what the purpose is. NEVER broke a spring on that car and it had 1100 open pounds of pressure.
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2399519
11/06/17 07:08 PM
11/06/17 07:08 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Just changed to PAC. Motorsports Unlimited was very knowledgeable. 216 390 4561.
Re: Manley NexTek Valve Springs [Re: camastomcat] #2400867
11/09/17 03:57 AM
11/09/17 03:57 AM
Boise
thegodfather Offline
Boise
**Was trying to PM you but, your PM box is full and will not accept anymore? Would like to talk to you about my B1 build since somewhere I read you’ve built 5 of them? Thx.
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2400924
11/09/17 11:56 AM
11/09/17 11:56 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I emptied a bunch of old PM's. You should be able to now. No problem talking to you about your build.
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2400987
11/09/17 02:18 PM
11/09/17 02:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you are breaking Nextek springs I’d better they are either not right for the application. Or more likely you have some interference with something. We have three B1 engines currently working fine with Nexteks.
Re: Manley NexTek Valve Springs [Re: Al_Alguire] #2401117
11/09/17 07:47 PM
11/09/17 07:47 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Bob Book had a rant on Facebook about PAC springs, it appears he has had a lot of breakages with them. He is switching over to PSI on all his stuff. That said, the springs he is using are around 550lbs of seat pressure, so it may not apply to what we do with our engines.
He was reporting instances of springs not making it off the dyno without breaking, when they were previously making through a race meet or two.
Alan Jones
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2401183
11/09/17 11:17 PM
11/09/17 11:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
He was complaining about a specific spring actually, the 1355H. Whish is a Pro Stock style spring. As with most things there is more to the story than what you saw posted.
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2401234
11/10/17 01:30 AM
11/10/17 01:30 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Not easy picking springs or anything in the valve train!
Them polished springs require see through valve covers runaway
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Manley NexTek Valve Springs [Re: Al_Alguire] #2401666
11/10/17 11:51 PM
11/10/17 11:51 PM
LA360 Offline
LA360  Offline
There always is! He certainly wasn't happy though!
Alan Jones
Re: Manley NexTek Valve Springs [Re: qwkmopardan] #2401671
11/10/17 11:55 PM
11/10/17 11:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
He has the right to be for sure. And he is not the only one. I KNOW that PAC knows they had issues with the high end stuff and with customer service. I also KNOW that the situation is being addressed and hopefully will be resolved. But only time will tell.
Re: Manley NexTek Valve Springs [Re: Al_Alguire] #2401719
11/11/17 01:36 AM
11/11/17 01:36 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Totally different conversation when the lift goes 1"+ and the ramps go steep...
