#2399068 - 11/05/17 06:49 PM Manley NexTek Valve Springs
qwkmopardan Offline
Loc: Affton MO
What is the differance in polished and non-polished springs. Polished over $200 more cash. All the installed heights are the same, pressures same at all listed heights. Longer life??? Worth the extra $200??
#2399086 - 11/05/17 07:16 PM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
rickraw Offline
Loc: Ambridge, Pa.
Polishing springs is like stress relief. Removes any imperfections that can cause fractures.
#2399092 - 11/05/17 07:23 PM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
HardcoreB Offline
Loc: Shelby Twp. Mi
Removes SURFACE imperfections/stress risers. That does NOT protect from inclusions inside the wire. They seem to have had a good track record for quality last time I checked but, I would do a quick internet search. Personally I wouldn't pay the extra money for this process.
#2399206 - 11/06/17 01:46 AM Re: Manley NexTek Valve Springs [Re: HardcoreB]
Dave Hall Offline
Loc: Cotati, CA
iagree That's $200 toward another set.
#2399358 - 11/06/17 11:13 AM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
Al_Alguire Offline
Loc: Rockville MD & Las Vegas
I ran Manley Nexteks for a very long time on the Cuda. Never went with the polished ones and yes I know what the purpose is. NEVER broke a spring on that car and it had 1100 open pounds of pressure.
#2399519 - 11/06/17 04:08 PM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
camastomcat Offline
Loc: Salt Lake City
Just changed to PAC. Motorsports Unlimited was very knowledgeable. 216 390 4561.
#2400867 - 11/09/17 12:57 AM Re: Manley NexTek Valve Springs [Re: camastomcat]
thegodfather Offline
Loc: Boise
**Was trying to PM you but, your PM box is full and will not accept anymore? Would like to talk to you about my B1 build since somewhere I read you’ve built 5 of them? Thx.
#2400924 - 11/09/17 08:56 AM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
camastomcat Offline
Loc: Salt Lake City
I emptied a bunch of old PM's. You should be able to now. No problem talking to you about your build.
#2400987 - 11/09/17 11:18 AM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
Al_Alguire Offline
If you are breaking Nextek springs I’d better they are either not right for the application. Or more likely you have some interference with something. We have three B1 engines currently working fine with Nexteks.
#2401117 - 11/09/17 04:47 PM Re: Manley NexTek Valve Springs [Re: Al_Alguire]
LA360 Offline
Loc: Melbourne , Australia
Bob Book had a rant on Facebook about PAC springs, it appears he has had a lot of breakages with them. He is switching over to PSI on all his stuff. That said, the springs he is using are around 550lbs of seat pressure, so it may not apply to what we do with our engines.
He was reporting instances of springs not making it off the dyno without breaking, when they were previously making through a race meet or two.
Alan Jones
#2401183 - 11/09/17 08:17 PM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
Al_Alguire Offline
He was complaining about a specific spring actually, the 1355H. Whish is a Pro Stock style spring. As with most things there is more to the story than what you saw posted.
#2401234 - 11/09/17 10:30 PM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
hemi-itis Offline
Loc: Great Neck,LI,new york
Not easy picking springs or anything in the valve train!
Them polished springs require see through valve covers runaway
HEMI-ITIS has no cure. My condition is fully BLOWN!!!
New best 60ft,, 1.42,1/8, 6.0 @117,, 9.38 @146.75 with 6 lbs boost @3700 lbs
#2401666 - 11/10/17 08:51 PM Re: Manley NexTek Valve Springs [Re: Al_Alguire]
LA360 Offline
There always is! He certainly wasn't happy though!
Alan Jones
#2401671 - 11/10/17 08:55 PM Re: Manley NexTek Valve Springs [Re: qwkmopardan]
Al_Alguire Offline
He has the right to be for sure. And he is not the only one. I KNOW that PAC knows they had issues with the high end stuff and with customer service. I also KNOW that the situation is being addressed and hopefully will be resolved. But only time will tell.
#2401719 - 11/10/17 10:36 PM Re: Manley NexTek Valve Springs [Re: Al_Alguire]
Dave Hall Offline
Loc: Cotati, CA
Totally different conversation when the lift goes 1"+ and the ramps go steep...
25,383 Registered Members
190,938 Topics
Pics wanted-71-74 B body manual trans
by Stroker
07/20/18 12:39 AM
1964 Dodge stepside peekup
by Neil
07/20/18 12:29 AM
Anyone else see this?
by justinp61
07/19/18 11:39 PM
Mopar Plus
by 340cpe
07/19/18 10:19 PM
