Proportioning valve for 1969 A body with Kelsey hayes #2398815
11/05/17 01:50 PM
11/05/17 01:50 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I am preparing to swap my drum brakes to a set of Kelsey hayes 4 piston discs---what is the right prop valve to use ???
Re: Proportioning valve for 1969 A body with Kelsey hayes [Re: Dart6pak] #2400290
11/08/17 01:26 AM
11/08/17 01:26 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
My 69 GTS has KH brakes. There is a prop valve, and a secondary valve located about a foot down the frame rail from the main prop valve.
If you are not going for original, you may want to look into an adjustable one.
-Dave
20060514 Pics (12).jpg20060514 Pics (13).jpg20060723 Pics 007.jpg20060723 Pics 005.jpg
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Proportioning valve for 1969 A body with Kelsey hayes [Re: Dart6pak] #2400334
11/08/17 03:02 AM
11/08/17 03:02 AM
Buy a adjustable good one so you can control the brakes the way you want them to be up twocents
I bought a Wildwood valve for my 1966 Dodge Coronet Deluxe and mounted on the inner left front fender well underneath the master cylinder where I can easily reach it to adjust it up
Re: Proportioning valve for 1969 A body with Kelsey hayes [Re: Dart6pak] #2400421
11/08/17 12:36 PM
11/08/17 12:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There is no proportioning valve in the 67-72 KH brake system on the A body , the main valve is really a distribution block , it is the same part drum or disc , there is the added hold off valve in the rear brake line. I did a swap on a friends 67 barracuda and used the adjustable valve from Wilwood in the rear line to adjust it to keep the rears from premature lock, wouldn't be a bad part to install in a a drum car either ...
