Re: Cal Tracs - Q & A [Re: PorkyPig] #2398132
11/03/17 08:48 PM
11/03/17 08:48 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By PorkyPig
Originally Posted By fast68plymouth
I ran the XHD springs with Cal Tracs....... No problems.
I wouldn't try and use them with SS springs though.
Keep in mind....... The bars were available for quite a while before the split mono-leafs were.
My Cal Trac/XHD combo replaced some well used SS springs, and the Cal Tracs were much more consistent, although best-to-best, they were no better.
I found the Cal Tracs made the rear of the car quite stiff for road use.
If you can find any old articles on the Calvert bars when he first started selling them, you may see that he developed them on a Super Stock Mustang with a 4 speed. And he used really stiff multileaf springs with that car. When I remember that it makes me wonder why the change to monoleafs.
Could be that they work better.
Re: Cal Tracs - Q & A [Re: clutch] #2398170
11/03/17 10:58 PM
11/03/17 10:58 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By clutch
Caltracs stock D100 4 leaf pack missing the overload leaf Rancho 9 ways 10" wide hoosier drag radials this was a couple of week ago
you can see in the slomo below less than 2' of rise in the rear at launch
Very nice, wish my 135mph sh1tbox would launch like that, dam Im 1/2 a second slower at the top.
Help
1963 Plymouth Max Wedge
1971 Barracuda
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398231
11/04/17 01:15 AM
11/04/17 01:15 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Let me back up a step....
I bought the car with the current setup installed, I am willing to ditch ALL OF IT so I am open to a complete package, all I plan to keep for now is the Yukon 3.91 8.75 rear (which is brand new from Dr. Diff). Tires, shocks, springs, etc. are all open to suggestions, BTW, car weighs 3,400lbs.
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398277
11/04/17 05:49 AM
11/04/17 05:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Myself I just run a set of 3400 lb Super Stock springs and the MP longer ext shocks. The pinion snubber made no difference once I put the new SS springs on my car. Its old school but its a street car and I like how it rides on the SS springs. My best 60 ft running 10.70's has been a 1.50 which I feel is ok for what setup I have on my car. I see cars running about the same #'s as me with Cal Tracs pulling 60's in the 1.40's. My guess is I could maybe pick up a tenth in my car with Cal Tracs and less body movement but it hooks good now on the SS springs. So I dont think its worth it for me to spend $800 or more as I would go with the mono springs to pick up maybe a tenth on a 99% street car. I live on a tight budget now so thats also one reason I have not gone to them. If I had the money to mess around with things on my car I would most likely give them a try but I dont have much play money and feel the SS springs work ok for me and how I use my car. Good luck to you Scott if you do go with them. I always hear many say that the Cal Tracs are best using the mono springs but as I say thats what I hear as I have never used them. Ron
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398286
11/04/17 07:55 AM
11/04/17 07:55 AM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
i like the assassin bars myself they have adjustments if needed and can be used on regular leaf springs
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398351
11/04/17 12:05 PM
11/04/17 12:05 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I run Cal-Tracs and Calvert's mono leaf spring on my Dart. Personally I don't like the 70's air shock look that comes with SS springs. Also they were of questionable quality for a period, made in mexico I think.
The front end has already been mentioned, I'd start there with a decent set of shocks and check the amount of travel you have. Have you tried clamping the front segment of your ss springs? What shocks on the back?
IMO Cal-Tracs are not a magic bullet and are not necessarily faster than a well set up set of ss springs, but they are more consistent and easier to adjust. If I were building another street/strip car and wasn't going to use either a four link or ladder bars I'd be on the phone with Calvert placing an order for springs and bars, but no shocks.
With your car being a four speed I agree with others on running a bias tire on the back, they are more forgiving than a radial.
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398457
11/04/17 05:56 PM
11/04/17 05:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea Ron, the current setup with the SS springs works "Ok" but I am redoing a lot of things he half arsed on the car. When he added the SS springs he didnt like the stance (high) so he added 3.00" !!! Lowering blacks to get the car to sit lower (and to his credit it does have a great stance) however I don't like the blocks and plan to ditch them, wouldn't mind keeping the current stance though, not sure what to do there.
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398735
11/05/17 11:34 AM
11/05/17 11:34 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Scott, I faced a similar delima with my 66'. I didn't like the stance with SS springs. I called Cal Trac, told them the height I wanted, weight of car etc. Two weeks later they were in the car and it sat EXACTLY where I wanted it. Call them and discuss it.
Re: Cal Tracs - Q & A [Re: Hemi ragtop] #2398795
11/05/17 01:20 PM
11/05/17 01:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks guys!
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398930
11/05/17 05:20 PM
11/05/17 05:20 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
In addition, put adjustable shocks up front and take your upper control arm bumper off if you haven't already. I drive mine everywhere on the 90/10 setting.
Oh, and better start looking at a Dana 60 as well... 😣
'63 Dodge 330
11.19 @ 121 mph
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398935
11/05/17 05:36 PM
11/05/17 05:36 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I am in the same boat as Ron, I love this hobby but don't have much play money and I can't afford a truck and trailer right now and don't have the ability to try new parts out so I built my car with budget in mind and I built it with a torquey motor to pull the 3.23 gears.
My factory stock leaf springs were starting to sag so I had a local leaf spring shop add one leaf to each spring which strengthened the front segment and made the car sit higher so I added one inch lowering blocks. I run Rancho shocks on the rear that were given to me with the adjustment knob on them. I have them set 3 clicks from full soft and may need to go a couple more clicks. Front suspension is bone stock. No snubber.
Yesterday I drove the car 50 minutes to the track, clicked off a 10.69 at 124.65 and drove it home. At the track I do switch rear tires from regular street radials to M/T 275/60 drag radial Pro's.
Tire technology has come a long way and these tires are phenominal.
There were big tire back-halved cars with lexan windows yesterday dialed a couple tenths slower than me and they were blowing the tires off. My 60 is only 1.51 but it hooks and books.
Re: Cal Tracs - Q & A [Re: ProSport] #2398940
11/05/17 05:47 PM
11/05/17 05:47 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Awesome! I used to drive mine to the track all the time but it sure is nice to trailer it, take the pit bike, popup tent, cooler, tools, lawn chairs...
It is fun having a mild, full interior street car that is faster than full boogie race cars and running them down when they get the light first!
'63 Dodge 330
11.19 @ 121 mph
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398958
11/05/17 06:06 PM
11/05/17 06:06 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Yea it's a blast but you're right, it's nice to have a truck and trailer for all the stuff you mentioned, especially if you're gonna be there for 2 or 3 days. I'm not planning on doing all that with this particular car, just an occasional cruise to the track for a few fun passes.
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398959
11/05/17 06:08 PM
11/05/17 06:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Prosport, great looking Duster man! How much power is your 440 making?
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2398976
11/05/17 06:28 PM
11/05/17 06:28 PM
Washington
madscientist Offline
Washington
By my math...if it weighs 3500 pounds...he's at about 520. Since it's not a full race car, I'd expect his HP to be closer to 550.
Providing my weight guess is accurate.
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2399008
11/05/17 07:21 PM
11/05/17 07:21 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I agree probably around 550HP. It's an all steel car with full interior, the motor is a very mild 10:1 compression 500" low deck with ported Eddy heads and small 557 purpleshaft cam along with small 1.75" B-body headers with a lot of dings. Lots of torque.
Re: Cal Tracs - Q & A [Re: ProSport] #2399011
11/05/17 07:26 PM
11/05/17 07:26 PM
Washington
Washington
Was I close on my eight guess?
Re: Cal Tracs - Q & A [Re: ScottSmith_Harms] #2399017
11/05/17 07:42 PM
11/05/17 07:42 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
It was 3275 with me in it at a local hardware store but I need to get a more accurate weight.
Re: Cal Tracs - Q & A [Re: ProSport] #2399021
11/05/17 07:57 PM
11/05/17 07:57 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Pretty much the same combo as me. My car is 3,600 lbs. with me.
'63 Dodge 330
11.19 @ 121 mph
Re: Cal Tracs - Q & A [Re: GY3] #2399026
11/05/17 08:19 PM
11/05/17 08:19 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
You are definitely running good at that weight.
I think mono springs with the Gazzard bros bars would be the hot ticket, or at least caltracs.
