Steering wheel quick releese on a Tuff wheel? #2397929
11/03/17 02:31 PM
11/03/17 02:31 PM
Indianapolis In. usa
Quickrunner Offline OP
Anyone done this? Pics?
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2397956
11/03/17 02:58 PM
11/03/17 02:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I am sure it can be done. I adapted a quick release to the wood grain wheel on my 70' Challenger. I even reused the quick flip seat belt buckle for my window net release as well.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2397980
11/03/17 03:29 PM
11/03/17 03:29 PM
Should mention want to do it with stock column.
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2398046
11/03/17 05:40 PM
11/03/17 05:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I did with a grant wheel 69 Satellite.I posted info but a while back.2yrs maybe.I can get a pic tomorrow.
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2398206
11/04/17 12:21 AM
11/04/17 12:21 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I bought a chunk of round stock and had a machinist buddy cut off a couple 1/4" disks and countersink holes to mount to the factory steering wheel and collar mounts. Works great and looks stock. I did cut the collar apart to shorten it 1/2" to move the wheel back to the stock distance. No horn at the moment but I'm planning to work that out this winter.
Fixed the orientation of the photos. Dumb iPhone.
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2398209
11/04/17 12:24 AM
11/04/17 12:24 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
More pics.
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2398212
11/04/17 12:27 AM
11/04/17 12:27 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Final results.
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2398304
11/04/17 09:07 AM
11/04/17 09:07 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My 64 wheel, similar, the original bowl is just a cover.
Doug
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2398979
11/05/17 06:31 PM
11/05/17 06:31 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Mine has a splined hub welded to a 2.5" washer that has 3 holes that bolt to the factory mount under the black cover.The center is held on by a shanked lug nut trimmed at the top to fit under the steering wheel center.
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2399286
11/06/17 12:18 PM
11/06/17 12:18 PM
Humpty, that is exactly what I was thinking. I sent ya a pm
Re: Steering wheel quick releese on a Tuff wheel? [Re: Quickrunner] #2399319
11/06/17 01:25 PM
11/06/17 01:25 PM
n.c.
geo. Offline
geo.  Offline
n.c.
I used the hex shaped quick release on a stock b body column.
had to trim the upper housing with a saw for clearance.
Slid the adapter over the column, drilled a hole and pinned the bottom 'cause I didn't want to weld near the column bearing. At the top I screwed on a stock lug nut, which centered the hex shaped adapter, then welded nut to adapter and threaded shaft to nut. Has held up to road-course use with manual steering since 1995.
