Main Caps #2396530
11/01/17 10:17 AM
11/01/17 10:17 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Getting a list of things together to put together a 400 based 511/512. Was looking around for main cap/girdles. Has anyone use the 440source kit of billet steel caps and girdle? Any fitment issues? I also see Milodon has Ductile Caps, the 3 middles ones or a set of 5. What's everyone using and liking?
Re: Main Caps [Re: DusterKid] #2396550
11/01/17 10:43 AM
11/01/17 10:43 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I expect you'll see a number of recommendations to go with aluminum main caps, instead of steel or ductile iron. I like the BCR caps, although I don't recall them being available when I had a different brand of aluminum caps installed on my "next build" block.
Lots of different opinions on the benefits of using a girdle, too. I think the combination of aluminum caps and a girdle makes sense, but not everyone will agree with me on that.
Re: Main Caps [Re: BradH] #2396555
11/01/17 10:57 AM
11/01/17 10:57 AM
Keymar, MD
Keymar, MD
The plan is to build it with around 10.5:1 compression, Steel Rod, Alum head and not rev it past 6500. Will be a race only engine, but going to try and build it fairly mild so it last for a long time. Not sure how that affects how crazy I should go with the main caps and girdle...
Re: Main Caps [Re: DusterKid] #2396573
11/01/17 11:39 AM
11/01/17 11:39 AM
an8sec70cuda Offline
If I was going to get new main caps for a stock block, they'd be aluminum.
I don't think the strength of the caps themselves is an issue, but softening the blow to the bottom end of the block is.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Main Caps [Re: DusterKid] #2396610
11/01/17 12:39 PM
11/01/17 12:39 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
The center 3 caps on mine are billet steel. Mine makes 838 peak and 776 average.
How long it will go like this I am not sure?
This current block in other configurations has over 300 passes on it. With the current configuration it has 54. So far so good. Will it fail someday....... Probably.
If a guy could get his hands on an aftermarket block that would be best. But for now this is what I have to work with.
I keep my fingers crossed everytime I let go of the button LOL.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Main Caps [Re: DusterKid] #2396615
11/01/17 12:53 PM
11/01/17 12:53 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we have the bcr caps and girdles available. we sell tons of them over seas as well as in the states.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Main Caps [Re: DusterKid] #2396620
11/01/17 01:06 PM
11/01/17 01:06 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I used a girdle with stock caps w/studs in my 440
Re: Main Caps [Re: DusterKid] #2396656
11/01/17 01:56 PM
11/01/17 01:56 PM
Milidon does not sell the Ductile iron caps now whiney
Do NOT use steel caps on a cast iron block tsk
I like and use to use ductile iron main caps on all my builds over 600 HP when I could buy them, now I use 440 Source aluminum with main studs, no girdles tsk twocents
I wish that we could buy good blocks with four bolt main caps and thick cylinder walls luck
Re: Main Caps [Re: Cab_Burge] #2396662
11/01/17 02:05 PM
11/01/17 02:05 PM
Keymar, MD
Keymar, MD
Cab,
Are you referring to P/N: 11361 (3 center caps) and P/N: 11365
(all 5 caps)?
Milodon still lists them on their website, Jegs and Summit list them as well but both have an expect delivery date in Dec...Doesn't mean they are available, but looks like they still make them, maybe.
Re: Main Caps [Re: DusterKid] #2396663
11/01/17 02:05 PM
11/01/17 02:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW, I run past 7000 r's on stock studded caps and have for 15+ years............ thumbs
Re: Main Caps [Re: DusterKid] #2396680
11/01/17 02:28 PM
11/01/17 02:28 PM
I called Milidon several weeks back to ask if their center ductile cap where machined for the thrust main bearing now, I had bought some years ago that where not machined for that bearing. I was told then that they are steel now, not ductile iron whiney
Re: Main Caps [Re: DusterKid] #2396684
11/01/17 02:41 PM
11/01/17 02:41 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I have the 440source aluminum main girdle kit. Works very well. I have never had an issue with it. I drove it on the street for 2 years. I took it in to get freshened up, and everything still looked great!
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Main Caps [Re: DusterKid] #2396834
11/01/17 06:51 PM
11/01/17 06:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I use 440source aluminum caps with studs as well. No issues yet. I do like the look of Jerrys caps better. They look to fit the block better imo a better design.
Re: Main Caps [Re: Cab_Burge] #2397005
11/01/17 10:24 PM
11/01/17 10:24 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Why ?
Street motor with around 500 HP that will never see the track or 6200 RPM's
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Main Caps [Re: bee1971] #2397011
11/01/17 10:32 PM
11/01/17 10:32 PM
IN
ahy Offline
ahy  Offline
IN
I bought (and still have) a set of Milodon ductile caps for a 400. The main bearing opening was machined for 440 size. No go. I have run steel caps and studs for ~15 years w/o issue with one freshen. Around 590 HP.
Re: Main Caps [Re: ahy] #2397019
11/01/17 10:38 PM
11/01/17 10:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I am running the BCR aluminum caps and girdle, nice stuff, it's up and running and all seems well. up
Re: Main Caps [Re: DusterKid] #2397060
11/01/17 11:15 PM
11/01/17 11:15 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I have Best Machine aluminum caps and ARP studs in my 500. But for the power and RPM you will be running, I don't think that any of it will be necessary. My old 440 made 575hp, launched at 5,000 rpm, shifted at 6,800 rpm and went over the traps at 6,500 rpm for many years. Never any problems on original caps and bolts.
[image][/image]
Re: Main Caps [Re: sgcuda] #2397088
11/01/17 11:50 PM
11/01/17 11:50 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
BRC alum caps and stud griddle on mine too. VERY nice set up (read; NO SHIMS!)
Good luck with yours, Brian
Re: Main Caps [Re: bee1971] #2397090
11/01/17 11:54 PM
11/01/17 11:54 PM
Why ?
Steel expands at a different rate than cast grey iron does, same thing on aluminum main caps, the expansion rate and holes in them do not expand the same as the cast iron does shruggy
Hence my preference of using cast ductile iron up
I had three RB blocks with cracked main webs whiney shruggy
The 400 blocks are way better to start with than any OEM 440 block for any build that you want to make more than 600 HP on pump gas or above 650 HP on race gas work twocents
Re: Main Caps [Re: Cab_Burge] #2397097
11/02/17 12:12 AM
11/02/17 12:12 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Why ?
You had 3 crack where others have had none,something going on there.
