Re: BB oiling
[Re: DusterKid]
#2396784
11/01/17 05:39 PM
11/01/17 05:39 PM
Posts: 4,457 Washington
madscientist
Washington
You will never go wrong using the biggest pick up you can get.
Re: BB oiling
[Re: DusterKid]
#2397122
11/02/17 01:11 AM
11/02/17 01:11 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I would go with external before trying to drill and tap for a bigger pickup. Pretty much a mill type operation, screw up and your buying a new block. A side note, make sure you plug the pickup hole in the block when you go to external oiling.
Re: BB oiling
[Re: DusterKid]
#2397124
11/02/17 01:23 AM
11/02/17 01:23 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
I looked at your title again, I won't enlarge the oil pump pick up hole in a stock block ever again after having two stock blocks crack there My last pump gas stroker motor made over 700 HP and I shifted it at or above 7000 RPM at every race with a stock 3/8 pick up and a stock 6 quart Mopar oil pan I do use the Milidon external dual line swinging pick up on some race motors also as well as the Milidon single line external pickup with the stationary pickup in the road race pan
Re: BB oiling
[Re: DusterKid]
#2397297
11/02/17 01:55 PM
11/02/17 01:55 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Car is a drag race only, BB in a A body with stock K frame, I do run an 8 QT pan, but with a 3/8 pickup. Current combo gets shifted at 6000 and crosses the strip around 6300-6400. Looking at building a 511 base on a 400 block and see that some grinding is needed near the pickup. Really don't want to go to the external oiling route, but I don't plan on spinning the motor over 6500 either. Just trying to get all the little details worked out before I start the build so I know exactly what I need and the route I need to take. I have been running an ext single line swinging p.u.for a long time with a stock k un cut 69 b body.The line just wraps around the front of the k and to the pan,no problem.
Re: BB oiling
[Re: DusterKid]
#2397318
11/02/17 02:40 PM
11/02/17 02:40 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I agree w/ rowin4...I'd go w/ a single line external pickup system before I bothered enlarging the p/u hole in the block to 1/2" NPT. Both of my street/strip motors have single line systems on them. Turning about 7500 rpm. One makes about 700 hp, the other 1100 hp. No issues.
Re: BB oiling
[Re: DusterKid]
#2397336
11/02/17 03:03 PM
11/02/17 03:03 PM
Cab_Burge
The two blocks that I tried to enlarge the pickups cracked when I installed the pickups On your next build my first 400 stroker motor was 4.375 bore with a 4.250 stroke crank on pump gas, it made peak HP at 5500 RPM, low deck Eddy six pack intake and stock type 440 carbs on a set of ported 906 heads, I ended up shifting at or above 7000 RPM to get the best E.T. and MPH. I swap the crank out to a 4.300 stroke to raise the compression from 9.25 to 1 with the original iron heads to 10.4 to with the new CNC ported Eddy RPM heads I put on three years later, it had the stock 1970/71 6 quart Hemi and 440 six pack oil pan with the stock 440 six pack 3/8 pick up from day one IHTHs
Re: BB oiling
[Re: an8sec70cuda]
#2397594
11/02/17 11:51 PM
11/02/17 11:51 PM
crabman173
crabman173
I agree w/ rowin4...I'd go w/ a single line external pickup system before I bothered enlarging the p/u hole in the block to 1/2" NPT. Both of my street/strip motors have single line systems on them. Turning about 7500 rpm. One makes about 700 hp, the other 1100 hp. No issues. Ding Ding Ding! We Have a Winner Crazy to screw around with a block--if you are at the level where it might matter go with single line external and FORGET about it Dual Line Milodons are not cool- they are a 60's bandaid-the Milodon pick up does not have the capacity to handle a dual line feed so that is why Indy has a swinging pick up that will! If a single line external will not keep your stock big block alive then you are doing something way wrong I also know of that 3/8ths pick up doing 4.80's for years that Sasquatch refers too--our pal ...knew what it takes--still does!! And it ain't what folks think that makes speed and durability Do not drill and tap ( way too shallow 99% of the time ) a stock block--you are fooling yourself and taking a chance on screwing up a good block It is not the answer for todays massive Mops
Re: BB oiling
[Re: Cab_Burge]
#2397610
11/03/17 12:17 AM
11/03/17 12:17 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Both NPT and NPS have the same thread angle, shape, and pitch (threads per inch). However, NPT threads are tapered and NPS threads are straight.
People usually argue with me on this, but if you have a factory unit and another with NPT, you can see the difference if you compare closely, and certainly can measure the difference.
Re: BB oiling
[Re: BSB67]
#2397623
11/03/17 12:36 AM
11/03/17 12:36 AM
Posts: 1,840 South Bend
John Brown
South Bend
People like to argue. I bought a set of NPS taps back in the 1970's for for putting drain plugs into aluminum Muncie transmission cases. They work fine for putting a tapered pipe plug into the straight hole. You don't end up with a plug that is sunk down like you will when someone taps a hole with a tapered pipe tap.
