413 max wedge? #2396494
11/01/17 07:21 AM
11/01/17 07:21 AM
Melbourne
O
ossietim Offline OP
ossietim  Offline OP
O
Melbourne
What say you real or fake?
Re: 413 max wedge? [Re: ossietim] #2396507
11/01/17 09:05 AM
11/01/17 09:05 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All I can say is the bores are notched at the top for exhaust valve clearance like a MW should have. scope
Re: 413 max wedge? [Re: ossietim] #2396517
11/01/17 09:42 AM
11/01/17 09:42 AM
gregsdart Offline
gregsdart  Offline
I would like to know the sonic check numbers on that block. I had a 426 block bored to .100 over and it ran very well.
Re: 413 max wedge? [Re: ossietim] #2396529
11/01/17 10:10 AM
11/01/17 10:10 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
looks like it has the bore notches - those stamping on the ID pad look a little different than what I have seen on the early blocks - but it is possible as there was no real consistency to the stamping as they were applied by hand on each block.
Re: 413 max wedge? [Re: ossietim] #2396544
11/01/17 10:31 AM
11/01/17 10:31 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Wouldn't 6-19-62 be for a '63 car and weren't the '63 max wedges 426's? Also, its blue instead of orange. I wonder if that block is from a Chrysler 300-J with the bigger exhaust valves...(1.74" instead of the standard 1.60" in '63 non Max Wedge big blocks). Maybe the engineers felt the need to unshroud the "big" exhaust valve in the special 300-J heads with those bore notches.
With my limited knowledge, I'd bet that block is from a full size '63 Chrysler.
Re: 413 max wedge? [Re: DoubleD] #2396551
11/01/17 10:47 AM
11/01/17 10:47 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
A 62 413 block should be stamped S41 a 63 would be T41. Not sure how the early 413 MW blocks would be stamped.
Re: 413 max wedge? [Re: ossietim] #2396645
11/01/17 01:49 PM
11/01/17 01:49 PM
AndyF Offline
AndyF  Offline
I've never seen a 413 block stamped 413. They usually said 41 on them but I'm no expert on MW stuff.
Re: 413 max wedge? [Re: ossietim] #2396747
11/01/17 04:31 PM
11/01/17 04:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The block casting number is correct for a '62 413 MW. The bore notches and stamping font/style looks correct. Does the block have the AAQA on the front?
The '62 MW was introduced mid-year and a June casting date could be a '62 model year (production usually ended on July 31 but the MW was built off-line).
Re: 413 max wedge? [Re: AndyF] #2396748
11/01/17 04:31 PM
11/01/17 04:31 PM
BradH Offline
BradH  Offline
I don't know if this has what you're looking for, but it's likely worth reading: http://racehemi.maxwedge.com/topics/castings.php
Re: 413 max wedge? [Re: ossietim] #2396791
11/01/17 05:51 PM
11/01/17 05:51 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
the stamping has the correct sequence as the later 426 MW blocks were 426TMP for Stage II and 426VMP for stage III
Re: 413 max wedge? [Re: John_Kunkel] #2396815
11/01/17 06:21 PM
11/01/17 06:21 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yes, see if it has this:
'63 Dodge 330
11.19 @ 121 mph
Re: 413 max wedge? [Re: GY3] #2396820
11/01/17 06:30 PM
11/01/17 06:30 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
What does the AAQA mean? I've got a reg. 413 block with AAQA and I know it's not a MW block.
Re: 413 max wedge? [Re: ossietim] #2396821
11/01/17 06:31 PM
11/01/17 06:31 PM
Melbourne
O
ossietim Offline OP
ossietim  Offline OP
O
Melbourne
Not sure if it has the AAQA .I was wondering about the mold set number , after the casting number .i don't know if all Max wedge blocks where a (1) and as you can see this one is (4) .
It's throwing me because the ID pad looks correct.
Re: 413 max wedge? [Re: ossietim] #2396829
11/01/17 06:46 PM
11/01/17 06:46 PM
dogdays Offline
dogdays  Offline
I think the dash number after the casting number has no bearing if it was going to be a Max engine or not.
I know nothing, but the stamping looks like factory stampings often do. The fact that the stamping has all three digits of the engine displacement, and that it has no year letter code tells me that it didn't come in a passenger car. In my mind the block is legit. But this is not my field of expertise.
R.
Re: 413 max wedge? [Re: DoubleD] #2396831
11/01/17 06:48 PM
11/01/17 06:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Learning something, mine had 426 TMP HC 63, can't remember the month. I got it in a 62 Dodge post car, spun bearing, whole car for $500
Re: 413 max wedge? [Re: ossietim] #2396843
11/01/17 07:00 PM
11/01/17 07:00 PM
AndyF Offline
AndyF  Offline
Yes, I've seen the 426 TMP HC stampings before with the large font stamp. I've never seen a 413HP stamp though. Not saying that proves anything since I'm sure I don't know everything.....
Re: 413 max wedge? [Re: ossietim] #2396846
11/01/17 07:02 PM
11/01/17 07:02 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
AAQA as I understand it was the foundry markings - I have seen street wedge 426 blocks with the same marking
Re: 413 max wedge? [Re: DoubleD] #2396850
11/01/17 07:08 PM
11/01/17 07:08 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
here is a 413 - note the use of a 1 as a dash - all were hand stamped so almost anything is possible
Re: 413 max wedge? [Re: ossietim] #2397440
11/02/17 06:42 PM
11/02/17 06:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The dash number following the main casting number refers to the number of core plugs changed in the casting core...all engines have them.
Re: 413 max wedge? [Re: ossietim] #2397609
11/03/17 12:14 AM
11/03/17 12:14 AM
Melbourne
O
ossietim Offline OP
ossietim  Offline OP
O
Melbourne
I was lead to believe all Max wedge blocks where the first core plug, the thickest walls of all castings.
All 3 max wedge blocks I have are the virgin core plug , ie (1)
So this being a 4 th plug change ,would that be a questionable tell to its originality?
