Re: 413 max wedge?
[Re: DoubleD]
#2396551
11/01/17 10:47 AM
11/01/17 10:47 AM
Posts: 1,565 tennessee
pushbutton
tennessee
looks like it has the bore notches - those stamping on the ID pad look a little different than what I have seen on the early blocks - but it is possible as there was no real consistency to the stamping as they were applied by hand on each block. A 62 413 block should be stamped S41 a 63 would be T41. Not sure how the early 413 MW blocks would be stamped.
Re: 413 max wedge?
[Re: ossietim]
#2396747
11/01/17 04:31 PM
11/01/17 04:31 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The block casting number is correct for a '62 413 MW. The bore notches and stamping font/style looks correct. Does the block have the AAQA on the front?
The '62 MW was introduced mid-year and a June casting date could be a '62 model year (production usually ended on July 31 but the MW was built off-line).
Re: 413 max wedge?
[Re: ossietim]
#2396791
11/01/17 05:51 PM
11/01/17 05:51 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
the stamping has the correct sequence as the later 426 MW blocks were 426TMP for Stage II and 426VMP for stage III
Re: 413 max wedge?
[Re: John_Kunkel]
#2396815
11/01/17 06:21 PM
11/01/17 06:21 PM
Posts: 4,684 Wichita
GY3
Wichita
Yes, see if it has this:
Re: 413 max wedge?
[Re: GY3]
#2396820
11/01/17 06:30 PM
11/01/17 06:30 PM
pushbutton
tennessee
Yes, see if it has this: What does the AAQA mean? I've got a reg. 413 block with AAQA and I know it's not a MW block.
Re: 413 max wedge?
[Re: DoubleD]
#2396831
11/01/17 06:48 PM
11/01/17 06:48 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
Learning something, mine had 426 TMP HC 63, can't remember the month. I got it in a 62 Dodge post car, spun bearing, whole car for $500
Re: 413 max wedge?
[Re: DoubleD]
#2396850
11/01/17 07:08 PM
11/01/17 07:08 PM
DoubleD
NE Ohio
here is a 413 - note the use of a 1 as a dash - all were hand stamped so almost anything is possible
Re: 413 max wedge?
[Re: ossietim]
#2397440
11/02/17 06:42 PM
11/02/17 06:42 PM
John_Kunkel
Rio Linda, CA
I was wondering about the mold set number , after the casting number The dash number following the main casting number refers to the number of core plugs changed in the casting core...all engines have them.
