Small block engine diaper #2396381
10/31/17 11:50 PM
10/31/17 11:50 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
Thinking of putting an engine diaper on my 65 dart. What are you guys using for engine diapers? Thanks Bradley
Re: Small block engine diaper [Re: roadrunnerreds] #2396444
11/01/17 02:06 AM
11/01/17 02:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://russlerii.com/
I'm fortunate enough to live close to Russ and both of my current small block mills have his diaper. The stock rear sump pan was pretty straight forward, but the pan on the R3 block was a different animal with it's dual kickouts and return oil lines. He's actually made blankets for quite a few members here. So far I'm happy to report I haven't personally tested one yet, but I'm hoping if I do, I'm not "that guy" that caused a lengthly and expensive clean up for the track.
