Re: Who all uses the Mini Starter?
[Re: FY1TA & 65 Wedge]
#239611
03/01/09 08:31 AM
03/01/09 08:31 AM
I'm using one from 440 Source, works great.
[Re: MoparforLife]
#239615
03/01/09 09:05 AM
03/01/09 09:05 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Mine was a reman and has been spinning the 440 for 10 years.My kid bought new 440 Source for the 413 and its 2 years.It cost about the same as a reman.Why spend a fortune on a car and them cheap out with junkyard parts to save a few bucks.Rocky
Chrysler Firepower
[Re: Pntastar69]
#239616
03/01/09 09:52 AM
03/01/09 09:52 AM
Posts: 3,312 Marine Corps Base Hawaii
DemonKyle
USMC LCPL
USMC LCPL
Junk yard, $30.
All the ones that I have used came from junkyards and I've yet to have a problem. Fits perfectly with the 360 in my Demon. 30 dollars and a chance to save parts from an old car, what better way to spend an afternoon.
[Re: redraptor]
#239619
03/01/09 11:50 AM
03/01/09 11:50 AM
Posts: 2,233 ILLINOIS
volaredon
ILLINOIS
Not me; the old #3258s are still plentiful-- these are the larger 1.8 HP version of the classic Mopar starter (got 2 fresh ones shipped to my door last month gor $50) and still have that telltale Mopar "whine" and they last pretty well, too; as long as you get a decent quality reman; that and they were Made in the USA, back when that meant something; on the minis, there are too many knockoffs being sold that were made in who knows where that won't last a season. That, and the simple notion that I actually have a couple usable spares here, means that it'll be that much longer before I need one; ain't it funny, how while you have spare parts sitting/collecting dust, they are not needed but as soon as you get rid of them, you wish you hadn't?
[Re: Challenger 1]
#239621
03/01/09 11:59 AM
03/01/09 11:59 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: 70dart360]
#239625
03/01/09 01:16 PM
03/01/09 01:16 PM
Junk yard, $30.
Same here (X 3) No problems with none of them.
X 4
#239626
03/01/09 01:27 PM
03/01/09 01:27 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Two here from Advanced with lifetime warranty. One on my 501 cid Coronet and one on my son's 363 cid Duster. ZERO issues.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#239627
03/01/09 01:49 PM
03/01/09 01:49 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I bought one from Manicini racing before I found out they were Dakota starters. Been on my 440 for 7 years now with only one problem. The ring gear slipped on my 440 flywheel! This was after I'd have the truck in low 4x4 on the trail in 1st or 2nd gear, and start it with the clutch pedal up. Just hit the key, and the 440 would fire up and roll down the trail no problem. The ring gear is now welded to the flywheel in about 6 spots. Did it through the inspection cover.
The main reason I bought the small starter, because in a big block truck with headers and stock starter, you have to first pull the header to get to the starter. Hooker headers actually touch the end of the stock starter. With the mini, I can pull the starter off without loosening the header. I've only had it off the truck once in 7 years, trying to figure out the ring gear slipping. That made a wierd noise!
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
[Re: MMiller]
#239628
03/01/09 02:30 PM
03/01/09 02:30 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I used to have the grungiest, nastiest dakota starter I've ever seen. I had it on my 4-speed without the shields on and somehow it got caught in the teeth and busted the snout.
I got a reman advance starter and it works great. So much easier to install as well. It would be really hard for a remanufacturer to screw up a nippendenso starter. There's almost nothing to them. I wouldn't use a stock starter unless it was on a Slant Six
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#239629
03/01/09 03:09 PM
03/01/09 03:09 PM
I bought mine new in the early 90's for $139.00. Best money I ever spent.....Still working fine.
