1967 440 vin number location? #2395524
10/30/17 05:52 PM
10/30/17 05:52 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Where would I find the vin number stamped on a 1967 440?
Re: 1967 440 vin number location? [Re: 440mopar] #2395528
10/30/17 05:57 PM
10/30/17 05:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nowhere if you mean 1967 model year?
If it was a '67 casting used for the 1968 model year, then look on top of the transmission bell mounting flange.
Re: 1967 440 vin number location? [Re: 440mopar] #2395529
10/30/17 05:57 PM
10/30/17 05:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
you wont. They didnt start stamping Vin #s till 1968.
Ive heard rumors SOME very late 67s got them ,but Ive never seen one
Re: 1967 440 vin number location? [Re: 440mopar] #2395532
10/30/17 06:01 PM
10/30/17 06:01 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
"Nowhere if you mean 1967 model year?"
Yes, 67 GTX specifically. So then a 67 motor can't be verified as the original to the car it is in?
Re: 1967 440 vin number location? [Re: 440mopar] #2395533
10/30/17 06:05 PM
10/30/17 06:05 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Nope.
No engine VIN stamps until the 1968 model year.
You can compare date codes & all that, but some cars were built later than hoped for, so even checking the dates can leave some doubt.
Re: 1967 440 vin number location? [Re: Alaskan_TA] #2395543
10/30/17 06:19 PM
10/30/17 06:19 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
O.K. My engine has casting #2536430 & 6 29 66 on the passenger side of the block and C440 HP 8 18 on the boss by the water pump. My build sheet shows a build date of 301 which I presume is March 1 of 1967 (if I am interpreting my build sheet correctly). What do you think the chances are of the engine being the original for my car with that much gap between dates?
Re: 1967 440 vin number location? [Re: 440mopar] #2395545
10/30/17 06:27 PM
10/30/17 06:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The date on the broadcast sheet is the SPD (scheduled production date) but the actual build date was not recorded on the sheet or fender tag.
The SPD is the date they hoped to build the car when the order was first entered into the system, but a lot of factors could affect actual build days.
Re: 1967 440 vin number location? [Re: 440mopar] #2395565
10/30/17 07:03 PM
10/30/17 07:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
8/18 is 8/18/66 , what are the other dates on the car , also look at the front of the K frame , it may have a 4 digit date code stamped on it , what does it say ?
Is the car original or restored ?
Re: 1967 440 vin number location? [Re: 440mopar] #2395570
10/30/17 07:09 PM
10/30/17 07:09 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
an "In Plant" date is on a St. Louis (plant #7) assembled broadcast sheet & a "Shipped" date is on a '67's IBM card
but the chance of an August '66 assembled 440HP block ending up 6+ months later in a February/March '67 assembled GTX are slim to NONE
care to share or email a pic of the broadcast sheet?
thanks - dhead68@hotmail.com
Re: 1967 440 vin number location? [Re: 6bblgt] #2395576
10/30/17 07:15 PM
10/30/17 07:15 PM
JohnRR Offline
JohnRR  Offline
I'm glad you said that ... I was thinking it ...
