Header paint? #239517
03/01/09 01:34 AM
03/01/09 01:34 AM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
I'm putting (old-style) Pro Parts RB headers in my '69 Barracuda. They are bare steel. Should I spend the $$$ to have them Jet-Hot coated, or is there a high-quality header paint available?
Re: Header paint? [Re: 300by500] #239518
03/01/09 01:43 AM
03/01/09 01:43 AM
so cal
cmcgee123 Offline
cmcgee123  Offline
so cal
how long do you want them to look good? if 2-3 months is ok use either bbq paint or the vht stuff is good too. if you want them too look great for a couple years spend 190$ and get em coated.
nitrous is like a really hot chick with an std you want to hit it but youre affraid of the outcome.
Re: Header paint? [Re: 300by500] #239519
03/01/09 07:59 AM
03/01/09 07:59 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
I used the VHT paint on bare headers and they still look decent after 2 years, put 3 thin coats and heat them with a torch after each coat. Make sure the headers are clean!!!
I will coat mine when I get some extra money.
Re: Header paint? [Re: 300by500] #239520
03/01/09 08:36 AM
03/01/09 08:36 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Take those new tubes to Nitroplate and have them coated right!! As a plus,they are in Nashville,so you won't have to send them.
www.nitroplate.com
Nautilus Racing-
Re: Header paint? [Re: Chris2581] #239521
03/01/09 09:11 AM
03/01/09 09:11 AM
Col. Ohio
The Avg. Valiant Offline
Col. Ohio
I thought jet coating was alot more than $190? Anyway, if your looking for a cheap great solution, go with Eastwoods header paint, awesome stuff. http://www.eastwoodco.com/jump.jsp?itemID=734&itemType=PRODUCT This is the color I used, but they have others. Alot of people have used this with great success
Re: Header paint? [Re: Chris2581] #239522
03/02/09 08:39 AM
03/02/09 08:39 AM
300by500 Offline OP
300by500  Offline OP
Nitroplate's website estimate for multi-piece V8 race headers is $330...
