Best head for a 6.1 based N/A 426 stroker #2395110
10/29/17 11:26 PM
10/29/17 11:26 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Ok with all the head flow numbers floating around what is the opinion on the best head to use. I have a 6.1 block but no heads. I am building a 4.080x4.080 stroker custom JE pistons shooting for 13.1 + compression with the goal of 750+ HP. This will be a carbureted setup with a Ritter intake I have the intake already. Starting from scratch on the heads what does everyone think ??
Re: Best head for a 6.1 based N/A 426 stroker [Re: biff426] #2395118
10/29/17 11:50 PM
10/29/17 11:50 PM
USA
hudsonhornet7x Offline
USA
For the money I like Thiteks for that setup.
Re: Best head for a 6.1 based N/A 426 stroker [Re: hudsonhornet7x] #2395132
10/30/17 12:07 AM
10/30/17 12:07 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
The Thiteks are so nice and well done that if I had the money, I would buy them.
The edelbrocks look nice. Might need to cut spring seat for dual valve spring.
I have seen the drag pack heads on Barton's hemi. Its just an Apache head with minimal amount of cnc work done in the ports. Barton said he made 840hp with the older .640 spec dp cam. The record motor was over 900hp.
I think the key to huge hp is spintron testing. David gave me a 15min lesson on spintron charts and Im grateful he did that
Re: Best head for a 6.1 based N/A 426 stroker [Re: sixpackgut] #2395143
10/30/17 12:34 AM
10/30/17 12:34 AM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
I am really considering the edelbrocks they look like the best bang for the buck. What do thiteks cost?
Re: Best head for a 6.1 based N/A 426 stroker [Re: biff426] #2395215
10/30/17 08:08 AM
10/30/17 08:08 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
A good set of Eagles will get you to 700, but Apache will get you in the 750+800 range.
6.1 heads are starting to come down in prices. not much call for them after the Eagles starting hitting the streets.
We bought 2 Trend Spintron 5000's over the spring, haven't a lot of time to work with them.
Re: Best head for a 6.1 based N/A 426 stroker [Re: ric3xrt] #2395295
10/30/17 12:32 PM
10/30/17 12:32 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Thiteks run around $3800 cnc ported complete with dual springs.
Re: Best head for a 6.1 based N/A 426 stroker [Re: ric3xrt] #2397529
11/02/17 10:18 PM
11/02/17 10:18 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
6.1 vs Eagle on 5.7 based build? Which one and why?
Re: Best head for a 6.1 based N/A 426 stroker [Re: moparmitch] #2397608
11/03/17 12:12 AM
11/03/17 12:12 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
On a stock 5.7 for street 6.1
On a stock 5.7 for track eagle
More comp out of eagle head
