Difference between '73 and '74 Duster Grill #239494
03/01/09 12:01 AM
03/01/09 12:01 AM
Gilbert, AZ
Aspen7695 Offline OP
Gilbert, AZ
I want to convert my '73 Duster to a '74 to change the class I run in. I can then run a 360 as opposed to a 340. I was told the only difference on the outside of the car is the front grill. I would like to know what the difference is between the grills, and if there are any other differences.
Raul
Re: Difference between '73 and '74 Duster Grill [Re: Aspen7695] #239495
03/01/09 12:20 AM
03/01/09 12:20 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I don't believe there is any.
Ride eternal, shiny and chrome
Re: Difference between '73 and '74 Duster Grill [Re: DirectSubjection] #239496
03/01/09 12:30 AM
03/01/09 12:30 AM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
I think in 1974, they have that plastic bumper filler behind the bumper, screwed to the bottom of the grille. I've parted them both out.
Re: Difference between '73 and '74 Duster Grill [Re: Aspen7695] #239497
03/01/09 12:52 AM
03/01/09 12:52 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
There is no difference in the grille.
Keep your same front end and just get a new (wider) rear bumper and put the rubber filler between it and the body (all 74's had this). You'll also have to change the rear bumper mounting system from brackets to shocks (this gives the gap which is filled by the rubber).
Presto its a '74 (if they don't check your VIN).
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Difference between '73 and '74 Duster Grill [Re: ChickMaggot] #239498
03/01/09 12:54 AM
03/01/09 12:54 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
74 has a emblem in the center if I remember correctly http://cgi.ebay.com/ebaymotors/ws/eBayIS...4&viewitem=
Re: Difference between '73 and '74 Duster Grill [Re: mopars4ever] #239499
03/01/09 12:55 AM
03/01/09 12:55 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
Emblem started in 75.
Re: Difference between '73 and '74 Duster Grill [Re: 1965_PLYMOUTH] #239500
03/01/09 12:57 AM
03/01/09 12:57 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
Early 74s had no filler. Late 74s did have the filler. It screwed to the metal filler below the grille.
Re: Difference between '73 and '74 Duster Grill [Re: ChickMaggot] #239501
03/11/09 09:16 PM
03/11/09 09:16 PM
Indiana
MonGoo$e Offline
MonGoo$e  Offline
Indiana
older post i know but if you convert the rear bumper completely to a 74, you'll have to modify the panel behind the bumper with large holes, then fab bolt anchors into the frame rails for the bumper shocks. good bet to just leave bumper as is, alot of Mopar guys don't even know the 73-74 rear bumper shell was different.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
