440 distributor question
#2394937
10/29/17 05:14 PM
10/29/17 05:14 PM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Hello all Maybe a stupid question but why the arrow on my 440 distributor reluctor points clockwise direction while the rotor,shaft etc turn counterclocwise? Could it be a reluctor from a small block dist? I don,t have spark and i noticed about this when i was checking things.Thanks
Re: 440 distributor question
[Re: Coke]
#2394939
10/29/17 05:25 PM
10/29/17 05:25 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I think if you take it out, and look on the other side, there is an arrow pointing the other way. So maybe it's been installed the wrong way.
If it's been installed the wrong way up, then it won't work as the 'points' won't align at the proper time.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Coke]
#2394957
10/29/17 06:13 PM
10/29/17 06:13 PM
RapidRobert
Coke there are no dumb questions. the reluctor is the same for SB/BB & that is why there are 2 roll pin locations & yes it (Rotor Phasing) is the SB roll pin location but in some cases it needs to be there on a BB for better RP. For a quick check line up the magnet with a tooth & install the rotor & make a mark on the top perimeter metal rim of the dist housing to show the rotor tip clocking location at that point then install the cap & see if the bulge of the cap terminal is close to (vertical/above) your mark, how close they are to each other. when cranking, the coil positive primary terminal and the blue/yellow ECU terminal both need to be fed at that point in time. In addition, a functioning (OE) five pin ECU the red/green terminal needs to be hot. More details: recent problem? what changes? what setup?
[Re: Coke]
#2395626
10/30/17 08:23 PM
10/30/17 08:23 PM
Coke
Vitoria, Spain
Thanks both Robert,what i did yesterday was to connect the wires of my multimeter to the dist.connector and turn the shaft by hand(The multimeter on the beep/continuity mode) and it made that a cricket insect sound. However, that signal does not arrive to the orange box.What i mean is that if i connect the dist connector to the car wiring and the multimeter wires to the orange box connector pins,the cricket does not sound. I don,t understand why, because there is continuity between the orange box connector pins and the connector that goes to the distributor. I did a video,is horrible because i was holding my celular so i only had one free hand,but more or less you can see what i checked out. https://youtu.be/5RKR3-KUo8w
[Re: Coke]
#2395935
10/31/17 10:43 AM
10/31/17 10:43 AM
RapidRobert
plug the zigzag connector halves back in & see if you have a reading at the ECU connector while spinning it with the scale on low AC volts then see if you have continuity with the scale on low ohms (no spinning needed) & always a good idea to pull a batt cable before switching the scale to ohms. See if the blue/yellow terminal at the ECU connector and the coil positive primary connector both have voltage in "run" and in "crank" (pull the yellow wire off of the starter relay to disable the starter), see if the meter chirps.
[Re: qwkmopardan]
#2398227
11/04/17 12:58 AM
11/04/17 12:58 AM
RapidRobert
Correct(ed), yes it is in the BB roll pin slot.
[Re: RapidRobert]
#2399305
11/06/17 01:02 PM
11/06/17 01:02 PM
Coke
Vitoria, Spain
plug the zigzag connector halves back in & see if you have a reading at the ECU connector while spinning it with the scale on low AC volts then see if you have continuity with the scale on low ohms (no spinning needed) & always a good idea to pull a batt cable before switching the scale to ohms. See if the blue/yellow terminal at the ECU connector and the coil positive primary connector both have voltage in "run" and in "crank" (pull the yellow wire off of the starter relay to disable the starter), see if the meter chirps. I tried what you said this weekend and i found that the zigzag con.didn,t make contact when the two halves were toghether. I replaced it for another zizag conector from an european Ford wiring that i had around here. Now i have spark but the engine does not start. I had an small fire on the engine bay some weeks ago.It afected to the dist.connector its wires,and also burned the distributor cap. I "fixed" the connector&wires using heat shrink and i put an old dist cap that i had. The engine used to start until the connector gave up the ghost,but i noticed that the dist did need to be advanced a lot for starting.
[Re: Coke]
#2399328
11/06/17 01:39 PM
11/06/17 01:39 PM
RapidRobert
bump the dampener with a 1&1/4" socket/breaker bar till the slit is at 15 BTDC. turn dist to where the magnet is dead even with the tooth that places the rotor under the #1 plug wire if you are on #1 compression or the rotor under the #6 plug wire if you are are on #6 compression (I'm assuming the intergear was not disturbed). confirm the plug wires are clocked 1-8-4-3-6-5-7-2 CCW around the cap & you mentioned burnt wireing so it wouldn't hurt to also confirm you have spark in "run" by turn the key "on" & crank it with a screwdriver on the starter relay & see if the coil wire sparks.
[Re: Coke]
#2409701
11/27/17 05:41 PM
11/27/17 05:41 PM
Coke
Vitoria, Spain
Robert,as i said in my previous post it has spark since i changed the burned dist. Connector.I use an scisor on the starter relay to check it out. However i don,t undestand the part when you say "Turn the dist where the magnet is dead" What i did today is to put a piece of paper in the #1 cyl.spark hole and turn the crankshaft until it has popped out.Then i have continued turning until the damper matched the 15 degress TDC. At this point if the rotor metal rivet is just under the dist. cap hole it should to start shouldn,t it?I have not tried to cranck it up.I will try tomorrow. About the intergear, if you refer to the gear where the dist takes movement,i put the sprocket in line with the crankshaft when the cyl#1 is at TDC.
[Re: Coke]
#2409763
11/27/17 08:21 PM
11/27/17 08:21 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
[Re: Coke]
#2409843
11/27/17 10:49 PM
11/27/17 10:49 PM
RapidRobert
However i don,t undestand the part when you say "Turn the dist where the magnet is dead" With the dampener at 15 BTDC #1 compression, you would turn the dist housing till the magnet is dead even with the reluctor tooth that locates the rotor above the #1 plug wire. Tho you can clock the intergear/#1 plug wire location anywhere around the cap, maintaining the OE pattern is a VG plan. Standing by the pass fender-vac can pointing across to the other side. #1 plug wire in the 5 O'clock terminal which will be just below the forward cap retaining spring clip.
