Best bore and stroke combo? #2394769
10/29/17 01:18 PM
10/29/17 01:18 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Starting my new engine build soon, with some budget minded changes in place. My goal is to run 7.90's. Car should weigh in around 2,200 lbs when done. Rear gear is 4.10, using 32 x 14.5 tires. Engine combo at this point is an Indy solid RB block, and Indy -1 345cc heads. From what I have calculated, I will need about 875hp and need to go over the stripe around 7,500 rpm.
At this point the block needs to be resleeved, and since it already was sleeved for 4.560" bore, I will resleeve it at that bore. I am also thinking about a 4.25 stroke crank. That will give me 555 cubes. I am going to use as long a rod as I can find, 7.10"+. My concern is if this is too many cubes to get the rpm I need. Would a 4.500" bore or a 4.150" stroke be better for high rpm use? I'm not worried about cylinder wall thickness, this block was run previously at 605 cubes on nitrous and survived until it broke a rod. The intake setup presently has 2 850's on it but will be upgraded to 2 1150 dominators soon enough.
Re: Best bore and stroke combo? [Re: sgcuda] #2394805
10/29/17 02:01 PM
10/29/17 02:01 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I know of 4.5 stroke engines redlined over 7500. 4.25 should be fine.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Best bore and stroke combo? [Re: Hemi_Joel] #2394807
10/29/17 02:04 PM
10/29/17 02:04 PM
sgcuda Offline OP
sgcuda  Offline OP
I know the bottom end can mechanically handle it. I was wondering what limits have been found on these heads to keep the rpm where I need.
Re: Best bore and stroke combo? [Re: sgcuda] #2394928
10/29/17 04:40 PM
10/29/17 04:40 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I thought it might take a little more power than that to run 7.90's.
2011 Drag Pak Challenger
Re: Best bore and stroke combo? [Re: sgcuda] #2394947
10/29/17 05:52 PM
10/29/17 05:52 PM
AndyF Offline
AndyF  Offline
My 514 makes 900 hp with EZ heads and a cast 4bbl intake. My engine is 4.440 x 4.150 and peak power is around 7000 RPM.
Your heads are bigger and better than mine so you should make more power. I think either 4.150 or 4.250 stroke will work for you. You'll need a big cam to put the peak power at 7500 rpm. My cam is 282/288 so you'll need to bigger than that.
Dwayne can get you all sorted out in terms of cam, lifters and springs. I don't think you need a tunnel ram to make 900 hp. It is a lot more money and more of a tuning hassle. If it was me I'd spend the money on EFI rather than a tunnel ram and two Dominators. The EFI setup will give you data acquisition as well as precise tuning.
https://www.youtube.com/watch?v=LZcFl7fy6FI
Re: Best bore and stroke combo? [Re: sgcuda] #2395014
10/29/17 07:48 PM
10/29/17 07:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
2200 with driver? Is this a door car?
Doug
Re: Best bore and stroke combo? [Re: dvw] #2395021
10/29/17 08:27 PM
10/29/17 08:27 PM
sgcuda Offline OP
sgcuda  Offline OP
Doug
Yes. 70 'Cuda, 2x3 frame rail, C/M cage.
Re: Best bore and stroke combo? [Re: sgcuda] #2395028
10/29/17 08:46 PM
10/29/17 08:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The moroso chart shows 890hp for a 7.90 @2200lbs.
That's as it sits on the line, uncorrected, in whatever air you're racing in at that moment.
I'd be shooting for about 950 std corrected hp......or more.
Something along the lines of Dougs motor but with a TR on it.
Re: Best bore and stroke combo? [Re: sgcuda] #2395066
10/29/17 09:56 PM
10/29/17 09:56 PM
gregsdart Offline
gregsdart  Offline
Why do you want to go through at 7500? A few more cubes, a taller tire or less gear will allow less stress on the valvetrain.
When I run the numbers and use my combo as a way to figure power needed, I suspect you will need more power than the -1 heads can provide. Mine shows 841 up at 2000 d's to run 8.88 at 3065 lbs. The same calculated said 2200 lbs running 7.90 at 175 would need over 900 hp. IMHO if you run in air similar to me you would be needing about 1000 dyno hp to be sure to meet your goal. That would take better heads to easily make the goal with a reliable motor.
Re: Best bore and stroke combo? [Re: sgcuda] #2395074
10/29/17 10:20 PM
10/29/17 10:20 PM
sgcuda Offline OP
sgcuda  Offline OP
Greg: Already running 4.10 gears with a 32x14 tire. I'm probably going to try a 33 if it clears ok, but that will only lower my trap rpm to 7150-7200. Trying to use what I already have.
[image][/image]
Re: Best bore and stroke combo? [Re: sgcuda] #2395082
10/29/17 10:32 PM
10/29/17 10:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Put the 4.5 in it for 587 inches. I doubt the price is any different. Why not?
Re: Best bore and stroke combo? [Re: Dave Hall] #2395086
10/29/17 10:34 PM
10/29/17 10:34 PM
sgcuda Offline OP
sgcuda  Offline OP
Price isn't any different. The problem is can I spin the engine to the rpm I need with the heads I have or will it choke?
Re: Best bore and stroke combo? [Re: sgcuda] #2395121
10/29/17 11:52 PM
10/29/17 11:52 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
2200 with driver is very light. My Cuda with a 2x3 frame mild steel cage and aluminum block was 2500 with me in it. I'm doing a 4130 25.1 chassis now and I don't expect mine to be down near 2200. Mine ran 8.50's. It made just over 900 on the dyno. Cuda's have a lot of frontal area to overcome, it would be interesting to see what it would run in a more aero car at the same weight.
Re: Best bore and stroke combo? [Re: sgcuda] #2395135
10/30/17 12:10 AM
10/30/17 12:10 AM
sgcuda Offline OP
sgcuda  Offline OP
I'm doing a 25.3 build. The only steel body parts are the quarters, tail light panel, rocker sills and roof. I have 225lb springs in the front struts. With the comlete steel block 500, flywheel, scattershield, trans, driveshaft, rear end, and steering in place, and me standing on the front crossmember, the front springs still don't even start to compress.
[image][/image]
Re: Best bore and stroke combo? [Re: sgcuda] #2395159
10/30/17 01:17 AM
10/30/17 01:17 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
Mine was also just the steel roof and quarters strut front and the bare minimum tube to meet the 8.50 cert. If you can get it to 2200 at the line you're doing real good.
Re: Best bore and stroke combo? [Re: B1HEAD_USER] #2395174
10/30/17 02:00 AM
10/30/17 02:00 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Yeah, that would be exceptional with you in it.
Re: Best bore and stroke combo? [Re: sgcuda] #2395209
10/30/17 07:16 AM
10/30/17 07:16 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
For a car the size of a Cuda' to get around 2200#, you will have to address every inch of the car......
Round tube 4130, with minimum bars for the required cert, aluminum block, mini-rad, lithium battery, carbon shaft, carbon body panels, 4130 rear, or Mark Williams modular, everything in the rear lightened (axles, spool, ring), the lightest wheel/tire combo for its size, lightest brakes, etc., etc., etc.
You can't leave anything out and you won't believe how fast the cash register rings when trying to get REALLY light.
Re: Best bore and stroke combo? [Re: sgcuda] #2395224
10/30/17 08:56 AM
10/30/17 08:56 AM
sgcuda Offline OP
sgcuda  Offline OP
Well, I guess we'll see how close I come to my estimate as the car gets closer to completion. up
Major weight losses so far have been :
1) Removed all excess metal from original shell including floor and firewall
2) Cast iron Hemi box replaced with magnesium DNE
3) Steel flywheel replaced with aluminum
4) Stock front end replaced with Strange strut and brake kit
5) Original frame, connectors, M/S backhalf changed to 2x3 rail
6) M/S cage changed to C/M
7) I lost 50 lbs (but gained back 20)
Re: Best bore and stroke combo? [Re: sgcuda] #2395258
10/30/17 10:58 AM
10/30/17 10:58 AM
gregsdart Offline
gregsdart  Offline
According to a formula I found, the kinetic energy in Parts increases at the square of the speed. 7200 rpm to 7500 rpm would be an increase of about 8 percent.
Add to that the energy and resistance to change in direction and control surge of the spring increases due to kinetic energy and that increases stress to another level .
Re: Best bore and stroke combo? [Re: sgcuda] #2395260
10/30/17 11:03 AM
10/30/17 11:03 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My bet is 2400-2600 w/o driver.
Doug
