Spring sliders? #2393408
10/26/17 04:06 PM
10/26/17 04:06 PM
Northern N.J.
hemi_doug Offline OP
Northern N.J.
I plan on using Caltracs with their mono leaf setup for my 65 Satellite build and was wondering if there is any advantage to using sliders vs stock spring hangers. Has anyone used sliders? What issue is solved with them?
71 440-6 4spd & 69 Hemi 4spd
Re: Spring sliders? [Re: hemi_doug] #2393413
10/26/17 04:24 PM
10/26/17 04:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've only ever seen sliders used in cars with leafs and ladder bars or 4 link to eliminate suspension bind. With a single pivot point (the front spring eye) there's no need.
ETA...NVM. I was thinking about old fashioned slider/floater assemblies.
Re: Spring sliders? [Re: hemi_doug] #2393429
10/26/17 04:45 PM
10/26/17 04:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes and my Dart came alive and so far got a best of a 1.33 60 ft leaving on the foot-brake at 2500 w/more to come...........Also, move your shocks as straight up as possible if you can......... thumbs
Re: Spring sliders? [Re: hemi_doug] #2393469
10/26/17 06:17 PM
10/26/17 06:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Much freer movement. Noisier.
Re: Spring sliders? [Re: hemi_doug] #2394121
10/28/17 02:17 AM
10/28/17 02:17 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
IMo if you go for it,get the cal trac sliders.I got the afco sliders and then had to buy the correct bushing from Caltrac.Save the hassle and get it right the 1st time.The afco bushing are for mopar SS springs.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Spring sliders? [Re: hemi_doug] #2394181
10/28/17 11:47 AM
10/28/17 11:47 AM
P
Porter67 Offline
Porter67  Offline
P
They go hand in hand with the whole caltrack/mono deal, look at your oem or even hd hangers, they just dont fit in the big picture.
Ive got the afco-s and there bushing fit well in the smaller al. one that came with my mono springs, but this was like 11 years ago. But this was before caltrac started selling them.
Re: Spring sliders? [Re: Stanton] #2394284
10/28/17 05:10 PM
10/28/17 05:10 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Looking at this and thinking...... with a mono spring & Caltrac bar setup, we all then use the shocks cranked down to as stiff as possible to slow the movement of the spring. So why would we want want to add a component frees up the movement of the spring?
Not saying they aren’t a good option, just thinking out loud and trying to understand what we accomplish with each step.
Thoughts......
Re: Spring sliders? [Re: StealthWedge67] #2394642
10/29/17 08:02 AM
10/29/17 08:02 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Thouhts......
My way of thinking too, The sliders theoretically make the spring rate more linear than shackles. My thinking is if the spring rate increased the more rise you have, then that would be better? As a caveat I have no way to verify this but I can see the leaf running into bind quicker with a shackle rather than a slider but it's also dependent upon shackle angle.
Re: Spring sliders? [Re: hemi_doug] #2394687
10/29/17 11:39 AM
10/29/17 11:39 AM
UK
rb446 Offline
rb446  Offline
UK
Both work well, sliders will allow the use of shock/bar adjustments a lot better.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Spring sliders? [Re: hemi_doug] #2394717
10/29/17 12:21 PM
10/29/17 12:21 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I asked Calvert about the sliders and this was the response:
"We recommend the sliders for drag race or street/strip applications, not for daily driver use, as they will make a metal to metal sound when encountering road hazards, driveway entries etc., since there is no rubber or poly bushing in the rear spring eye."
"The sliders eliminate any potential bind in the rear suspension, instead of the suspension relying on pivoting on a shackle bushing and bolt, the spring rolls in the slider with two roller bearings per spring.
If a shackle is too tight or bound up in any way, it can cause the spring to not pivot at all or slowly, which can cause the suspension to hop or bounce on the tires, slow down the 60 ft and also effect the consistency."
Bill
Re: Spring sliders? [Re: hemi_doug] #2394720
10/29/17 12:25 PM
10/29/17 12:25 PM
P
Porter67 Offline
Porter67  Offline
P
Rear shacks still allow alot of movement but in a slightly different way. I mounted mine in a way that the spring eye is in the same location as the oem shack had placed it.
Although now as fast as some/many my street racer hits 6.0s at the track 1/8 and most the time I can dead hook on the street if its concrete, is it the sliders, no, just mix of good parts and the longest front segment of the caltrack bar I could come up with using, I think its 24 inches, "I think".
I dont like to copy others but if you look at some of the really really fast caltrack cars and they use sliders as well.
Re: Spring sliders? [Re: Porter67] #2394736
10/29/17 12:44 PM
10/29/17 12:44 PM
hemi-itis Offline
hemi-itis  Offline
I would like to know how you dead hook on concrete! Is the surface prepped at all? What brand and size tire ? What does your car weigh?
I have ZERO luck with traction with no prep.
Re: Spring sliders? [Re: Stanton] #2394743
10/29/17 12:53 PM
10/29/17 12:53 PM
kansas city missouri united st...
'68cuda416 Offline
'68cuda416  Offline
I run the sliders on my car and I’ve never once heard them.
Re: Spring sliders? [Re: hemi_doug] #2394772
10/29/17 01:22 PM
10/29/17 01:22 PM
hemi-itis Offline
hemi-itis  Offline
Mine are quiet as well.I'll just add no matter which method is used,a good shock is needed needed to control the movement.
Re: Spring sliders? [Re: hemi-itis] #2394798
10/29/17 01:50 PM
10/29/17 01:50 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
What he said up
Re: Spring sliders? [Re: Tig] #2394804
10/29/17 01:57 PM
10/29/17 01:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Who the hell can hear them over my Magnafuel 300 pump and bullets anyhow.............lol
Re: Spring sliders? [Re: hemi-itis] #2394830
10/29/17 02:38 PM
10/29/17 02:38 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've been doing a few street tire events (300 treadwear or better tire) and had a couple of street races. I use 275 ET Street Pro's when I can, 110 lbs in the trunk directly over the rear bumper and leave in 2nd gear. I won runner up about a month ago at in an '80 and older true street tire class. 1.72 60 ft. And ran 11.70's on a true street radial.
Here is launching on true street 275's. 20 psi.
'63 Dodge 330
11.19 @ 121 mph
Re: Spring sliders? [Re: hemi-itis] #2394831
10/29/17 02:39 PM
10/29/17 02:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My Cal-Tracs make quite a bit of noise on the street...
'63 Dodge 330
11.19 @ 121 mph
Re: Spring sliders? [Re: hemi-itis] #2394876
10/29/17 03:36 PM
10/29/17 03:36 PM
P
Porter67 Offline
Porter67  Offline
P
M@H 325/50 DR, I can dead hook if some rubber gets down so I try to run mid pack, but thats foot brake vs off idle. Old Old concrete state highway.
With the mt sportsman bias 28/12.5 I get a little spin but in a good way imo.
Simple a body with coil over front, double adjust rear shocks and a S60 made between a early 70-s b body and c body width, iirc I the rims are 10 inch with a 5.5 bs. 3050 is the weight.
Ive tried a std. hoosier 275/60/15 DR and havent had really good results
Re: Spring sliders? [Re: GY3] #2394888
10/29/17 03:46 PM
10/29/17 03:46 PM
Puyallup, WA
Puyallup, WA
Do you have sliders?
