Re: Blocking the heat crossover in iron heads.
[Re: Porter67]
#2393637
10/27/17 01:00 AM
10/27/17 01:00 AM
RapidRobert
I like to keep the horse shoe openings in the middle of the head open to air & block the passages in the intake itself.
[Re: Porter67]
#2393716
10/27/17 10:10 AM
10/27/17 10:10 AM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
If your car is primarily driven on the street and used during colder weather, I personally would leave the cross-over open. I blocked the cross-over in a 383 powered car I had. The change made it very "cold blooded." If the car is equipped with a factory type thermostatically controlled choke, the choke will take way too long to pull off. If you have an electric choke, it will pull off too soon. Plus, blocking the cross-over didn't make any noticeable improvement after the engine was "warmed up". I think this is one of those questions to which the answer is, it depends.
[Re: RapidRobert]
#2393719
10/27/17 10:18 AM
10/27/17 10:18 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I like to keep the horse shoe openings in the middle of the head open to air & block the passages in the intake itself. This is what I have always done to any of my cars as well. They don't get driven in winter anyway.I just use a couple of small thin piece of sheet metal & sandwich them in with the gaskets. Never had any intakes leaks either.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Porter67]
#2393758
10/27/17 11:48 AM
10/27/17 11:48 AM
Posts: 74 Stevensville, ON
Frank Raso
Stevensville, ON
As in the title im looking for opinions on if still blocking the heat crossover is a plus or if anyone figured out it might keep more heat then wanted in the inner cylinders. There is no benefit to blocking the intake manifold heating system on a street-driven engine. The hot-spot under the carb is necessary to vaporize any fuel that falls out of the air stream and to replace the heat from the vaporizing fuel's cooling effect on the intake manifold. See the Carter, Holley, and Rochester references in Intake Manifold Heat. Even with an al. intake wont it heat sync nearly as hot sooner or later? Nope. Without a working cross-over passage you won't have a hot-spot under the carb either.
[Re: Porter67]
#2393879
10/27/17 04:51 PM
10/27/17 04:51 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Not to high jack, but kind of the same subject... Would it be beneficial to remove the heat riser valve in the exhaust manifold? The reason I ask is mine are rusted in place. Usually partially open. Street cars, summer use.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2393885
10/27/17 05:02 PM
10/27/17 05:02 PM
Posts: 737 Michigan
BlueRacer69
Not to high jack, but kind of the same subject... Would it be beneficial to remove the heat riser valve in the exhaust manifold? The reason I ask is mine are rusted in place. Usually partially open. Street cars, summer use. That's a reasonable suggestion. Back in the day we used to take a piece of wire and wire the heat riser open.
[Re: BlueRacer69]
#2393896
10/27/17 05:15 PM
10/27/17 05:15 PM
bboogieart
Lost and Spaced
O.K. Open it will be. I will remove 'em and drill and tap for plugs. As well as the intake block-of R.R. recommended. Thanx.
[Re: Porter67]
#2394100
10/28/17 12:43 AM
10/28/17 12:43 AM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I had to fill the cross overs with epoxy because one of the darn things sprang a leak...LOL, yeah, all iron heads, heavily ported, so it is conceivable that maybe this had something to do with it, although the machine shop did a pressure test first and there was NO air coming out of the ported exhaust valve area.
Anyways, to answer your question, on top of this I used FelPro 1213S-3 intake gasket, which has the passages blocked off.
This is on a street car, but not a daily driver. Car heats up just fine (I only drive it in late spring, summer and early fall months), no issues to report.
[Re: Porter67]
#2394355
10/28/17 08:07 PM
10/28/17 08:07 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The aftermarket heads seem to work just fine without a heat crossover passage.
[Re: Frank Raso]
#2394421
10/28/17 10:42 PM
10/28/17 10:42 PM
bboogieart
Lost and Spaced
So block off the exhaust heat riser, but not the Intake cross-over? Good to know. Now I can use the pan gasket I already have.
[Re: fast68plymouth]
#2394474
10/28/17 11:58 PM
10/28/17 11:58 PM
Porter67
The aftermarket heads seem to work just fine without a heat crossover passage. The smog heads I just did, they go up on both center exhausts unlike the older j or x for instance that just go up on one, thats why I asked about heat buildup.
[Re: Porter67]
#2394541
10/29/17 01:32 AM
10/29/17 01:32 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Back in the 70'S I used tin foil which worked OK. Then some gasket manufacture had little squares of thin metal gasket material to place over the hole. Later race type gaskets were introduced that didn't have the crossover opening.
[Re: Porter67]
#2394646
10/29/17 08:34 AM
10/29/17 08:34 AM
Posts: 1,513 AZ
Mike P
AZ
I’ve also found exactly the same thing 2many62s describes especially on cold mornings.
“……If the car is equipped with a factory type thermostatically controlled choke, the choke will take way too long to pull off. If you have an electric choke, it will pull off too soon. Plus, blocking the cross-over didn't make any noticeable improvement after the engine was "warmed up". I think this is one of those questions to which the answer is, it depends…….”
While not as bad as eliminating the heat crossover, eliminating the heat riser will also slow the warm up period considerably. None of my cars have a heat riser valve and a few in the past have run manifolds and/or heads without the heat crossover. As I often drive my cars year around and during the winter and we get some pretty chilly early mornings I can say first hand it can be a real PIA.
The one band-aid I’ve found that really helps during the warm up period is to add an MSD box. The multiple spark during low RPM really makes a big difference in firing off the cylinders until the car warms up.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
