Re: Starter relay recomendation
[Re: floridian]
#2394054
10/27/17 11:09 PM
10/27/17 11:09 PM
RapidRobert
they are pretty trouble free, I would get a used one from a yard or by mail from someone on here.
[Re: floridian]
#2394193
10/28/17 12:59 PM
10/28/17 12:59 PM
Posts: 4,452 Morristown Tn.
71birdJ68
Morristown Tn.
If the points are in good shape on your original, just take the cover off, and have it replaced. All of the new ones I have seen except the ones that R E. of Mopar Action has cheap and smaller points and coil. Not as heavy duty as factory.
[Re: 71birdJ68]
#2394402
10/28/17 09:57 PM
10/28/17 09:57 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
If the points are in good shape on your original, just take the cover off, and have it replaced. All of the new ones I have seen except the ones that R E. of Mopar Action has cheap and smaller points and coil. Not as heavy duty as factory. Its not the original... I have had an off and on no crank. When I wiggle the wires to it, it will crank and start... Noticed one of the connections has a loose rivet so I was going to replace it.. Looking for a quality part so I thought I would ask on here...
[Re: floridian]
#2394795
10/29/17 01:47 PM
10/29/17 01:47 PM
RapidRobert
there was a guy on here selling converted to electronic, voltage regs that had an OE black cover, mrrandyj at aol dot com I ain't sure if he is the guy but it might be worth an inquiry.
[Re: RapidRobert]
#2394812
10/29/17 02:14 PM
10/29/17 02:14 PM
floridian
Lakeland FL
there was a guy on here selling converted to electronic, voltage regs that had an OE black cover, mrrandyj at aol dot com I ain't sure if he is the guy but it might be worth an inquiry. TY, but I am pretty sure he is not the one... Seems as if the person was heavily involved with Chargers?????
[Re: floridian]
#2394883
10/29/17 03:42 PM
10/29/17 03:42 PM
Posts: 114 Oregon
Wagonman1967
Had the same intermittent no start had to wiggle the wires problem with a Re-pop relay. Yup loose rivet, got one from Napa a Standard or Echlin brand and made in the USA, problem solved.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
[Re: bremotorsports]
#2395668
10/30/17 09:41 PM
10/30/17 09:41 PM
floridian
Lakeland FL
I have NOS original starter relays in stock at all times. Bill Rolik www.billrolikenterprises.comPunch in 2444442 (for automatic relays) or: 2444453 (for manual trans relays) into the green SEARCH button. 201-394-5533 Cellular bremotorsports@verizon.net PayPal preferred. Thank you
[Re: Wagonman1967]
#2395670
10/30/17 09:41 PM
10/30/17 09:41 PM
floridian
Lakeland FL
Had the same intermittent no start had to wiggle the wires problem with a Re-pop relay. Yup loose rivet, got one from Napa a Standard or Echlin brand and made in the USA, problem solved. Appreciate your comment here.. Makes me hope I am on the right track Thanks
