Page 6 of 6 1 2 3 4 5 6
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2393061
10/25/17 08:32 PM
10/25/17 08:32 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
One more, this time showing the 1.59 annular vs the 1.52 downleg carbs... neither of which are really dialed in at this point.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2393067
10/25/17 08:43 PM
10/25/17 08:43 PM
AndyF Offline
AndyF  Offline
That looks like a toss up. The 1.52 is a little choppy but that could be due to something else. Sometimes a dyno pull just gets choppy for some reason. How much air was the engine using during the pulls? 800 cfm or thereabouts?
Re: All the specs to start your dyno #s guesses! 8^) [Re: AndyF] #2393250
10/26/17 09:08 AM
10/26/17 09:08 AM
BradH Offline OP
BradH  Offline OP
Peak airflow #s ranged from about 880 to 900, depending upon carb & spacer combination.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2393319
10/26/17 12:36 PM
10/26/17 12:36 PM
AndyF Offline
AndyF  Offline
Did you get all of the data in a .txt file so you can dump it into Excel? If so then you can look at avg power for different runs and area under the curve. Those will tell you if you have any difference or not between parts.
Re: All the specs to start your dyno #s guesses! 8^) [Re: AndyF] #2393424
10/26/17 04:38 PM
10/26/17 04:38 PM
BradH Offline OP
BradH  Offline OP
Nope, just standard printouts. Any data analysis requires me to fat-finger it all in. tonguue
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2393440
10/26/17 05:03 PM
10/26/17 05:03 PM
AndyF Offline
AndyF  Offline
There might be a way to export the files. Worth checking on since I'm sure you'll want to play with that info. The dyno software we use has an option of outputting the file in .txt format which you can then read into Excel. Makes it really nice for analysis.
Re: All the specs to start your dyno #s guesses! 8^) [Re: AndyF] #2393709
10/27/17 09:44 AM
10/27/17 09:44 AM
BradH Offline OP
BradH  Offline OP
My fingers need the exercise. laugh2
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2393718
10/27/17 10:16 AM
10/27/17 10:16 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Can I ask what the BSFC numbers look like?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2393785
10/27/17 12:46 PM
10/27/17 12:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
On the sheet I'm looking at, they start out in the very low .4's, and start creeping upward into the mid-4's at around 5800rpm, then into the upper-4's at 6800 till the end of the pull(7200).
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2393789
10/27/17 12:54 PM
10/27/17 12:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
One thing I did notice was the run w/ the QF 1.59 annular using the 32 MABs actually made more power across the RPM range, even though it went rich at the very end, than the subsequent runs where we leaned out the MABs.
In hindsight, I think a jet change might have been a better move than an air bleed change.
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2393863
10/27/17 04:01 PM
10/27/17 04:01 PM
BradH Offline OP
BradH  Offline OP
Yeah... but we were out of time... and I was about out of $$$.
We did what we could in the amount of time we had. Still learned a lot, just a few more take-aways to follow up on than I probably expected. shruggy
