cam lobe fundamentals Q #239362
02/28/09 10:06 PM
02/28/09 10:06 PM
ILLINOIS
V
volaredon Offline OP
V
ILLINOIS
I have a 318 LA that I am putting Magnum heads onto (EQ, "318-b" ones, if it matters)
I am putting a stock, standard, 360 2 barrel cam in along with it. (extremely similar to a COMP 252, minus 0.015" of lift which I will gain back and a lil more with the Mag 1.6 rocker ratio) but the standard 360 cam was 1/2 the price of the COMP, though it did take me a bit more work to find one than it would have for the COMP version.
I know that instead of 0.410" lift with standard LA shaft rockers, (1.5 Rocker ratio) with the Magnum 1.6s I will have 0.437---or something like that--- will duration, overlap, etc increase the same amount as the lift will?
Re: cam lobe fundamentals Q [Re: volaredon] #239363
02/28/09 10:13 PM
02/28/09 10:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
No. The duration, while yes it changes, but is very minimal in comparison to the lift.
Re: cam lobe fundamentals Q [Re: volaredon] #239364
02/28/09 10:20 PM
02/28/09 10:20 PM
Only the lift changes with the increased 1.6 fulcrum. The lifter still comes back to the base circle on the cam at the same point on the degree wheel & everything is the same ex when the lifter starts to rise the valve is opened 1.6 times that lift amt rather than 1.5 times that amt. EDIT yes .410" X 1.067 = (new lift of) .437"
Re: cam lobe fundamentals Q [Re: RapidRobert] #239365
02/28/09 10:29 PM
02/28/09 10:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
when changing rocker ratios the area under the curve increases. seat timing remains the same, .050 duration may change 1 degree, .200 lobe lift duration increases 5-7 degrees with a 1.5 to 1.6 ratio change. to notice the effects of ratio change camshaft duration must be measured at the valve.
Re: cam lobe fundamentals Q [Re: lewtot184] #239366
02/28/09 10:32 PM
02/28/09 10:32 PM
I stand corrected. I thought only the lift(amt) changed(when going from 1.5 to 1.6)
Re: cam lobe fundamentals Q [Re: RapidRobert] #239367
02/28/09 10:44 PM
02/28/09 10:44 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you could graph it out you'd notice the change. seat timing is fixed but lift increases meaning the valve will travel more in the same length of time. it's interesting to mock up a block-crank-piston and measure different cams at the lobe and then put a head on and measure at the valve with different rockers. once you see the changes you take rocker ratio changing and the effects little more serious. another thing about measuring at the valve is one finds what the true ratio is, and one finds out that "rated" ratios are not accurate.
Re: cam lobe fundamentals Q [Re: lewtot184] #239368
03/01/09 11:44 AM
03/01/09 11:44 AM
ILLINOIS
V
V
ILLINOIS
Cool and thanks; but 1* difference @0.050 isnt really that much; but compared to the orig stock 318 cam, at 0.373 int/0.400 exh and 240* int/0.248* exh, and the fact that I hear constantly that stock OEM LA rockers are rarely accurate at 1.5 (often 1.3X-1.4 RR) going to the stock 360 cam+ the 1.6s should really be a noticable power/torque improvement.
are the Magnums any more true to their listed ratio?
Re: cam lobe fundamentals Q [Re: volaredon] #239369
03/01/09 02:10 PM
03/01/09 02:10 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
stock rockers being that far off is pure myth. you'll find that aftermarkets are more off than factory. i've checked a few stamped rockers and they were all on the money. there's a lot of heresay and people repeating what some clown on some website says. to find the truth do your own checking, then you'll know.
Re: cam lobe fundamentals Q [Re: lewtot184] #239370
03/01/09 09:19 PM
03/01/09 09:19 PM
ILLINOIS
V
V
ILLINOIS
thanks again for the info; Mag heads are on new cam n lifters are in but I dropped a da#n pushrod thru the lifter valey right into the pan, so off it came; I'm just glad its on a truck as I didn't have to monkey with jacking up the engine from its mounts, etc; just means I won't have it finished up completely til tomorrow. (dinner break now)
