5.7 hemi in 05 Dakota #2393338
10/26/17 01:20 PM
10/26/17 01:20 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Been thinking of doing this for awhile. The V6 in it now is getting a little tired so I have this hemi setting around and thought why not. Anybody on here done this? If so what do I need to get to install? No racing or pulling just normal driving. Will the V6 trans bolt up (4x4)? I have the car intake, I know I have to replace that and would like to keep the throttle cable instead of the fbw. Thanks for any help
Re: 5.7 hemi in 05 Dakota [Re: cudaman1969] #2393609
10/26/17 11:54 PM
10/26/17 11:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I'd be really surprised if the V6 trans bolts up to the 5.7. Even if it did, I wouldn't expect it to live very long.
I've heard that some of the stuff from a 4.7 swaps to a 5.7, but have no experience to back it up. At least a 4.7 was an option in an 05 Dakota. I can tell you nothing interchanges between a 5.7 and a 5.9 Magnum.
An 03 full size Ram still had a cable throttle that adapted to a 5.7, might be your best choice for that. We did a 5.7 from an 03 Ram, I can tell you that early 5.7 truck intake is a pretty strange looking thing, but it sets the throttle body back and lower then most of the other 5.7 intakes.
I think wiring is going to be your biggest challenge. Hot Wire has a stand alone 5.7 Hemi harness, but it ain't cheap.
Might be worth taking your question to the Modern Hemi forum here on Moparts. Those guys deal with these things a lot. Gene
