Steering Column Help #2392972
10/25/17 04:57 PM
10/25/17 04:57 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
I dropped my steering column down while installing a mew speedo in my 70 Challenger 440RT, Now, with everything reinstalled, key worked the ignition and starter, but I cannot remove the key from the column. To drop the column, I removed the two 3/8nuts from under it and loosened the 3 bolts on the plate to the firewall. Any advice on what I might have screwed up or how to troubleshoot and fix? Thanks
Re: Steering Column Help [Re: 70VERT] #2392983
10/25/17 05:39 PM
10/25/17 05:39 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Is it column shift?
Re: Steering Column Help [Re: Dave Hall] #2392994
10/25/17 05:57 PM
10/25/17 05:57 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Did you readjust the lock out linkage?
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Steering Column Help [Re: 70VERT] #2393000
10/25/17 06:22 PM
10/25/17 06:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it is a '70 model, adjust the lockout linkage if needed, but if it is a 4-speed car,the shifter must also be in reverse to remove the key.
