Cuda side marker reflector #2392207
10/24/17 08:59 AM
10/24/17 08:59 AM
NJ
JH23 Offline OP
JH23  Offline OP
NJ
I removed and polished the lense on my 70. I see there is an adhesive backing on the reflector. Whats my best bet to adhere it back to housing and so I can remove it in the future without breaking? I also want to make it sit flush against the marker lense.
Re: Cuda side marker reflector [Re: JH23] #2392224
10/24/17 10:16 AM
10/24/17 10:16 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Reflectors have a metal backing and double back adhesive, easy way is to pull this and replace with aluminum tape and double back adhesive tape, trimmed to the periphery (carefully) using a new, sharp, razor blade.
Of course once you stick it back in, good luck getting it out, that double back tape I use will make it near impossible
