top bulbers/button users #2391716
10/23/17 11:52 AM
10/23/17 11:52 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
I'm thinking of trying top bulb racing next year. Still have the original steering wheel in my car, would like to see some pics of where and how your buttons are mounted. Thinking I would like to mount it to the steering wheel somehow, but not sure just yet.
Re: top bulbers/button users [Re: DusterKid] #2391756
10/23/17 01:05 PM
10/23/17 01:05 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Not a stock wheel but... I had to make a little "L" bracket to tuck it up in the corner like that. Remember to drive around in second or high gear because you will bump it accidently sometimes. Only works in 1st or reverse.
Re: top bulbers/button users [Re: DusterKid] #2391857
10/23/17 03:25 PM
10/23/17 03:25 PM
gregsdart Offline
gregsdart  Offline
I have mine on the steering wheel too. Use my thumb for the button.
Re: top bulbers/button users [Re: DusterKid] #2391922
10/23/17 05:12 PM
10/23/17 05:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I am another with it on the steering wheel. I tried it down by the shifter for awhile and was just never comfortable or consistent there.
Re: top bulbers/button users [Re: DusterKid] #2391936
10/23/17 05:38 PM
10/23/17 05:38 PM
Renton Washington
Triple Threat Offline
Renton Washington
Stock wheel here. My button is down low by the shifter.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: top bulbers/button users [Re: DusterKid] #2392003
10/23/17 07:47 PM
10/23/17 07:47 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I made a extension bracket off the dash about three inches to the right of the wheel and foward two inches so it was easy to reach being relaxed and comfortable. Never interfering with the steering wheel. Whatever you do make it have NO movement or it will affect your reaction time. Didn't have to put up with that springy cord wrapping around the steering wheel either. Also had my practice tree box wired in so I could practice while waiting in line. Freaked the drivers out.
Re: top bulbers/button users [Re: DusterKid] #2392029
10/23/17 09:11 PM
10/23/17 09:11 PM
HR3128 Offline
HR3128  Offline
This is the button set-up that was in my car when I got it. I like it. I can position my hand on the bracket while staging, stage & push the button. The button is out the way & won't get bumped accidently. I added the switch on the side to operate the brake solenoid for reverse.
Re: top bulbers/button users [Re: DusterKid] #2392132
10/24/17 12:40 AM
10/24/17 12:40 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
A few top bulb guy's I know use a rocker switch mounted on the steering wheel. They claim it is more consistent as you can concentrate on the tree not holding the button. With your thumb on the high part of the rocker switch as the light comes on a slight pressure flips the rocker and your off. Anyone else use a rocker switch?
Re: top bulbers/button users [Re: rowin4] #2392150
10/24/17 01:36 AM
10/24/17 01:36 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
There is no way a rocker switch will be as consistent as a button. I remember the "Trans. Trigger" was sorta kinda popular for awhile. It looked like a shifter handle with a gun trigger. I haven't seen any lately.
Re: top bulbers/button users [Re: DusterKid] #2392454
10/24/17 05:57 PM
10/24/17 05:57 PM
rowin4 Offline
rowin4  Offline
Being a stick shift guy I never got into the pull your thumb/arm off a button but I think the rocker switch might require less concentration then holding the button in.
Re: top bulbers/button users [Re: DusterKid] #2392467
10/24/17 06:26 PM
10/24/17 06:26 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I've never had mine on the wheel, it's down near the shifter. A person could use the horn button for the stealthy look when the stock steering wheel is in place. work
