Page 4 of 6 1 2 3 4 5 6
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391528
10/22/17 11:26 PM
10/22/17 11:26 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Brad,
Thanks for sharing your results. How much HP did you gain with each 2* of timing? Did you only test the baseline carb at 34* timing? I wondering how close the baseline carb would have been with 38* timing and the 1" spacer, and whether your original carb is the best solution for a street car?
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391540
10/22/17 11:56 PM
10/22/17 11:56 PM
Washington
madscientist Offline
Washington
Originally Posted By fast68plymouth
The part-throttle was rich on all of them, not lean, and really out of normal range in at least one case.
And not just a little rich either........some were way way rich with light loads simulating highway driving.
Under those conditions, the main circuit is already flowing plenty of fuel,........and you're not going to lean out the mixture by 3.5 points by tweaking an air bleed.
All the carbs had a tendency to richen up throughout the run(both the turbines and O2 agreed).......some worse than others.
- Enough of the carb stuff I saw didn't make sense to me that I ended up stealing Quick Fuel's tune (as much as I knew, at least) for the 1.59 v annular rather than use what I'd intended
And, as I recall, it seemed to have the flattest fuel curve.
Do you think if you had the time to sort it out, you could have made some emulsion changes to clean up the middle?
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391556
10/23/17 12:31 AM
10/23/17 12:31 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Keep in mind the wot a/f ratios were fairly decent on both the QFT carbs when they made their best runs.
So, whatever you do to lean out the part throttle cruise, you're trying to do something that changes that part of the carbs operation by around 3 points......and have essentially zero affect on wot operation.
There are smarter guys with carbs than me, but I have a feeling it's easier said than done.
The QFT 1.52 carb had the least offensive part throttle cruise operation when it was first bolted on.......low/mid-12's, with the 80/90 jets.
However, with that set up, the motor didn't take a load real well, and I aborted the run about 800rpm into it when I saw the a/f ratios weren't getting out of the 15's.
Once the jetting was increased to get the wot a/f ratios in line, and the power up......which ended up being 88/98....... then the part throttle cruise was down at the bottom of the 11's.
The Demon had the next best part throttle operation, low-12's, and had the best throttle response.
IMO, this carb is probably the best candidate of what we ran to be tweaked to get decent part throttle operation for street use.
The down side of this carb as we ran it was, it had the biggest change in wot a/f operation from the bottom of the run to the top........it really richened up at the top end.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391563
10/23/17 12:46 AM
10/23/17 12:46 AM
AndyF Online content
AndyF  Online Content
Running a power valve on both sides helps on the dyno but might not work at the track.
Re: All the specs to start your dyno #s guesses! 8^) [Re: davenc] #2391591
10/23/17 02:08 AM
10/23/17 02:08 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Originally Posted By davenc
Brad,
Re timing...
- One comparison between 34 and 38 using the same carb & spacer picked up 15 HP and almost 8 lbs-feet at their respective peaks.
- Going from 34 to 36 on a different carb & spacer combination picked up 13+ HP, but only about 1.5 lbs-feet; from 36 to 38 didn't pick up any HP (actually lost 2 at peak), but the engine got into the 670s 100 RPM sooner & stayed above 670 for 100 RPM later, and picked up 3.5 lbs-feet.
- No, never tried the Race Demon with the Super Sucker and more ignition advance. I'll need to spend more time on it when the car is running again to see what it does.
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391647
10/23/17 09:58 AM
10/23/17 09:58 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thanks BH/DP for posting.
This (WOT fuel curve, cruise) mirrors my past results.
Did you look at the boosters at cruise RPM and the A/R befor the booster started flowing? Mine was fat before they were flowing and not flowing much at the lower RPM. The IFR did matter. My testing was in the 2000 to 2500 range.
Do you believe that if you did track testing under similar conditions, and based on et and mph, you would have come up with the same hierarchy?
Do you believe that cruise numbers in the 12s will truly cruise poorly on the street.
Finally,based on what an O2 sensor is really measuring, and how low the fuel flow/air flow measurements are (relative to their span) how robust do you thing the cruise A/F numbers are?
Re: All the specs to start your dyno #s guesses! 8^) [Re: BSB67] #2391663
10/23/17 10:34 AM
10/23/17 10:34 AM
BradH Offline OP
BradH  Offline OP
My scoring methodology is to add the differences in estimated HP and torque from the actual results for each category. If there is a tie, then the same approach based upon RPM differences would be the deciding factors.
Winners:
- Baseline test - RAMM
- Best test - 572B1
FWIW, 572B1 was also 2nd in Baseline, and Triple Threat was 2nd in Best with a score only 1 point behind 572B1!
Being that the winners are both outside the USA (Canada and Australia, respectively), I'll need to ask Summit how I can award the Gift Cards if mailing them is an issue... primarily a concern for 572B1. Would both of you please PM me your mailing addresses? Thanks - Brad
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391665
10/23/17 10:41 AM
10/23/17 10:41 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Since this is a street car, were you running a PCV valve? Then tend to lean out the low to mid-range without having much affect up top.
Joe
Without Data, you’re just another guy with an opinion.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391689
10/23/17 11:12 AM
10/23/17 11:12 AM
tboomer Offline
tboomer  Offline
Brad and Dwayne.. This has been a great thread! Very informative. Get that thing into the car! wave
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391735
10/23/17 12:32 PM
10/23/17 12:32 PM
So. Burlington, Vt.
So. Burlington, Vt.
Russ, on the carbs where the part throttle cruise was in the low 12's, the motor was running smoothly enough where I don't think it would drive bad at all.
I've had quite a few years and plenty of examples to look at, and when they come off the dyno like this, and get put right into the car without getting the part throttle a/f ratios into a more favorable range....... The trend does seem to suggest that the instrumentation isn't lying.
Those motors end up getting abnormally poor fuel mileage, plugs that are always dark, and sometimes even gassy smelling oil.
I had a really mild 505 on the dyno about a week ago.
It had a Holley 850vs on it.
Jets 80/88, part throttle operation very crisp and clean in the low-14's, WOT in the 12's & 13's.
No tendancy to get "fat" at any throttle or load setting.
That carb was a good match for that motor.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391751
10/23/17 12:58 PM
10/23/17 12:58 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good reading. Thanks for sharing your work!
I actually came here wanting to talk about carbs a bit, but after reading this, it seems it might be a bad time to ask questions
Rich H.
Esse Quam Videri
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391765
10/23/17 01:20 PM
10/23/17 01:20 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I would be very pleased with those hp figures on a stock stroke motor with that comp, that would put my 3200# car solidly into the 9's The timing aspect suprised me as well.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391773
10/23/17 01:40 PM
10/23/17 01:40 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
My 512 likes a lot of timing as well. It actually runs the fastest by leaving the starting line at 42 degrees and then I retard it at 5,000rpm 4 degrees to 36. An engine needs what fuel it does no matter how you feed it, cab or EFI. A well set up carb I understand makes more power doe to the cooling effect of the fuel vaporizing in the intake. But getting a carb RIGHT requires a lot of effort, drill airbleeds, power valve restrictions etc. The main advantage to EFI in my opinion is you do all your work an a lap top and if you screw up it is easy to go back to what works. On a card sometimes your changes are hard to undo.
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391797
10/23/17 02:10 PM
10/23/17 02:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'm sure that would help with the part throttle.
Did you guys mess w/the emulsion cos you can change the mixture quite easily in the range needed buy the location and sizes.........
Re: All the specs to start your dyno #s guesses! 8^) [Re: Thumperdart] #2391823
10/23/17 02:58 PM
10/23/17 02:58 PM
Washington
Washington
That's what I was getting at. My thinking was adding some bleed in a middle hole, or if there was already a bleed there, open it up a bit.
Am I thinking on the correct lines?
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391841
10/23/17 03:10 PM
10/23/17 03:10 PM
gregsdart Offline
gregsdart  Offline
Congrats on a great build Brad. It will "haul the mail" as they would say back in the day up
What will your car weigh when ready? We have a little time for "guess your ET" !
Re: All the specs to start your dyno #s guesses! 8^) [Re: madscientist] #2391858
10/23/17 03:27 PM
10/23/17 03:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly what I've done on the street w/interesting results and yes, adding bigger or smaller not necessarily more changes things pretty quickly and so do the hi-speed bleeds............The richness imo has a LOT to do w/a healthy bigish motor sucking through small venturi's/boosters makin em go rich and I see it all the time on my car and if they put a real carb on that beast(1050 dommy of course) that will change guaranteed.......... thumbs
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391861
10/23/17 03:30 PM
10/23/17 03:30 PM
an8sec70cuda Offline
Nice job! HP is about where I expected it to be. Makes more torque than I thought it would though.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391870
10/23/17 03:49 PM
10/23/17 03:49 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Went back to look at the list of carbs.
Did 6A make it on the motor? Figure that carb might've had a little calmer emulsion than some of the others.
Originally Posted By BradH
1. BG Race Demon RS set up w/ 1.42" venturi sleeves
=> previous tune as used on my car when it ran 10.5s as driven to the track
So... that means you can pick two (2) of the remaining carbs listed.
2. BG Gold Claw set up w/ 1.50" venturi sleeves
=> new & untested config
=> pushing the limit for venturi size w/ downleg boosters that I believe will work well on my car
3. QFT/Proform 1.45" venturi main body used as basis for complete carb
=> original boosters; new & untested
=> Basically a Proform "950" with a better tune
4. QFT/Proform 1.52" venturi main body used as basis for complete carb
=> BLP modified boosters; new & untested; this is the limit for venturi size w/ downleg boosters I'll try
=> comparable to a QFT Race-Q 1000, which Quick Fuel used to win the small-block class in the last BLP Carb Challenge held a few years ago
5. QFT/Proform 1.59" venturi annular booster main body used as basis for complete carb
=> comparable to a QFT Race-Q 1050-AN, which AndyF said has been the best performing 4150 carb he's tested so far
6a. Holley Ultra HP/XP 1.60" venturi carb re-fitted with Mark Whitener's custom annular boosters
=> purchased from AndyF 'cuz I thought it looked "interesting"
=> Dominic "Thumper Carbs" worked on the tune to make it more driveable vs its original dyno tune
6b. Same as #6a, only with Holley Ultra HP/XP 1.56" venturi main body blended out to 1.58" and equipped with the same 12-hole annular boosters as the #5 carb
=> Mark Whitener's flow testing of a variety of carbs showed the modified Ultra HP/XP 1.56" (1.58") venturi main body flowed noticeably better than Holley's 1.60" venturi body... so I decided to build one
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391884
10/23/17 04:10 PM
10/23/17 04:10 PM
Get the intake ported and dial in one of those carbs and you will be over 700 hp.
If you sell all of the carbs except for the one you want to run you'll be able to pay someone to port in the intake. If you sold all of your carbs and your intakes you could buy an EFI setup. But of course, EFI can be a hassle to put in a car since you need to change the fuel system. Might be E body tanks available now that are EFI ready though. I had to modify the tank in my Coronet and that wasn't any fun....
