440source.com Water pump housing and water pump #239167
02/28/09 08:11 PM
02/28/09 08:11 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Anybody buy thier aluminum water pump housing and pump for big blocks? any comments or advice? Thanks!
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: 440source.com Water pump housing and water pump [Re: 1AARCUDA] #239168
02/28/09 08:14 PM
02/28/09 08:14 PM
MO
cdp Offline
cdp  Offline
MO
you might do a search as I think this has been discussed before. I think there is mixed feelings. Some have been good, others that had some bolt locations off a little on the T-stat housing.
They may have corrected this issue by now. If I remember right, the return/replace policy has been very good on these housings.
Re: 440source.com Water pump housing and water pump [Re: 1AARCUDA] #239169
02/28/09 09:19 PM
02/28/09 09:19 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Went back 19 weeks nothing there, maybe should have gone back further. anyone?
Re: 440source.com Water pump housing and water pump [Re: 1AARCUDA] #239170
02/28/09 09:37 PM
02/28/09 09:37 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Bolt holes on the T stat housing are off a bit as stated.
Some members have had to use a thick gasket on the pump to housing mounting for proper clearance as the impeller may hit the back of the housing.
I used the gasket that came with the combo and didnt have an issue.
Re: 440source.com Water pump housing and water pump [Re: NTOLERANCE] #239171
02/28/09 09:45 PM
02/28/09 09:45 PM
MO
cdp Offline
cdp  Offline
MO
Re: 440source.com Water pump housing and water pump [Re: cdp] #239172
02/28/09 09:55 PM
02/28/09 09:55 PM
NY NY
3
340duster340 Offline
NY NY
aluminum water pump housings are also on ebay for stupid cheap.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: 440source.com Water pump housing and water pump [Re: 1AARCUDA] #239173
02/28/09 10:01 PM
02/28/09 10:01 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Thanks for the input!
