where does these cable go #2391664
10/23/17 10:35 AM
10/23/17 10:35 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
69 b body heater control panel have two cables where does the temp cable connect two on heater box.is it closes to accelerator pedal or close to the passenger side connector?the temp cable is the one on the left side of control panel.see pics below.thanks
Re: where does these cable go [Re: moparpro] #2391731
10/23/17 12:26 PM
10/23/17 12:26 PM
I dont have an exact answer but with the lever moved to DEF whichever cable end moves it would be connected to the door that now directs flow up to the defroster vents in the dash if that helps
Re: where does these cable go [Re: moparpro] #2391742
10/23/17 12:40 PM
10/23/17 12:40 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The defroster/heat cable goes on the left side of the box.
