Page 3 of 6 1 2 3 4 5 6
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391395
10/22/17 07:37 PM
10/22/17 07:37 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
QFT 1.52" v with BLP downleg boosters, 38* timing, 1" Super Sucker spacer
- 677.7 at 6800, 603.3 at 5100
- gained power with each additional 2* advance
- too lean with starting 80/90 jets; ended up with 88/98
- part throttle not great
QFT 1.59" v annular, 38* timing, 1" Super Sucker
- 678.0 at 6800, 606.8 at 5100
- going rich above 6700
- part throttle even fatter than the 1.52 downleg
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391399
10/22/17 07:42 PM
10/22/17 07:42 PM
BradH Offline OP
BradH  Offline OP
QFT 1.52 downleg, 38*, 2" Super Sucker
- 684.2 at 6800, 606.2 at 5000
- the "Big Number Run" although I would not be able to use a 2" spacer with an air cleaner, even with my raised T/A scoop
tonguue
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391420
10/22/17 08:27 PM
10/22/17 08:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I am very surprised it liked 38* timing.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391423
10/22/17 08:36 PM
10/22/17 08:36 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
We ended up putting 5 different carbs on the motor, and all were briefly tested for part throttle operation.
At a variety of low loads(35-80-ish hp), at a variety of rpm's(2200-3200), looking at A/F ratios being displayed from the flow turbines and a Daytona Sensors wide band showed that none of the 5 had what either of us considered "acceptable" part throttle operation...... with the best of them being in the low-12's, and some in the 11.0-11.2 range.
They worked perfectly well to use on a "race car", but wouldn't be the hot ticket on the street(in their current configuration).
I can't believe I'm going to say this........but........this is an example of a good argument for EFI.
Re: All the specs to start your dyno #s guesses! 8^) [Re: Clanton] #2391430
10/22/17 08:49 PM
10/22/17 08:49 PM
So. Burlington, Vt.
So. Burlington, Vt.
Originally Posted By Clanton
Can you post a couple tq# from 3k rpm?THX!
The pulls were started at 3500.
Once we started to get it dialed in, the tq at 3500 was a little over 500.
Things didn't really start to happen until it was closer to 4K.
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391438
10/22/17 09:03 PM
10/22/17 09:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thank you for all of your results!
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391444
10/22/17 09:11 PM
10/22/17 09:11 PM
The Great White North
RAMM Offline
RAMM  Offline
You did better than I thought on HP but I was fairly close on my TQ guess. IFR and PVCR circuits are always too big it seems for part throttle operation. Good job Brad and Dwayne and thankyou for sharing this. Brad your big block is going to feel like a supersized small block with this power and RPM. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: All the specs to start your dyno #s guesses! 8^) [Re: CSK] #2391454
10/22/17 09:42 PM
10/22/17 09:42 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
my 440 liked the same 38/39. my 505 is 35 iirc
a function of efficiency
Well done Brad and Dwayne , good to see the results
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391480
10/22/17 10:22 PM
10/22/17 10:22 PM
AndyF Offline
AndyF  Offline
Yep, Holley carbs are almost always rich in the mid-range. On the dyno you can crutch it by turning the idle screws in since you don't usually need the idle circuit on the dyno. On a street car it needs to be sorted out. On the dyno we typically use the idle screws to get the mid-range cleaned up and then use the main jets for WOT. It takes way too much time to mess with the PVCRs during testing. Besides, it all changes once the engine goes in the car so no reason to mess with the carb twice.
And I agree with your EFI comment. Once you start tuning EFI engines you'll wonder why people waste their time with carbs!
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391484
10/22/17 10:25 PM
10/22/17 10:25 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Why do you say that? Just because nobody had time to fix a part throttle lean issue? An EFI system with a lean part throttle concern is still going to need calibration also. 5 minutes booting up a laptop or 5 minutes changing a bleed. I had someone drive over their laptop on a test day. Guess how much data we got that day?
Re: All the specs to start your dyno #s guesses! 8^) [Re: tex013] #2391489
10/22/17 10:31 PM
10/22/17 10:31 PM
BradH Offline OP
BradH  Offline OP
Still about 2 hours out from home & Mike's driving again.
Miscellaneous comments...
I wasn't expecting it to want that much ignition advance. My Stage VIs' sweet spot was 35, which is why we started out about there. But we weren't seeing the results until bumping it up; 36 was better than 34, but 38 was better yet.
The Race Demon fuel curve made no sense given what I'd seen before. We went from .026 MABs to .028, but it wasn't much change. At that point we yanked it off and started testing other carbs.
Things that ended up NOT like I'd expected:
- More torque by about 20 #s... and the peak RPM wasn't really any different than where it was for the old combination
- Harder to get "big" HP numbers, and I'd been HOPING we might be closer to 700, although Dwayne & I agreed it "should" make 670+ before it was tested
- Peak HP RPM... thought it would be around 6500... didn't think the small CSA heads and moderate cam would keep pulling that high
- NONE of the carbs were really "right", even after some tweaking
- The 1.52 downleg needed WAY more jet than I thought it should; we also appear to have maxed out fuel flow capacity of the metering blocks used, since adding more secondary jet stopped much in secondary fuel flow increases before we got to the 98s
- Enough of the carb stuff I saw didn't make sense to me that I ended up stealing Quick Fuel's tune (as much as I knew, at least) for the 1.59 v annular rather than use what I'd intended
Re: All the specs to start your dyno #s guesses! 8^) [Re: sgcuda] #2391496
10/22/17 10:39 PM
10/22/17 10:39 PM
BradH Offline OP
BradH  Offline OP
The part-throttle was rich on all of them, not lean, and really out of normal range in at least one case.
It was a loooong day. Met Dwayne a the dyno at 8:00 AM, last pull was close to 7:30 PM. Then time to break it all down, etc.
Re: All the specs to start your dyno #s guesses! 8^) [Re: RAMM] #2391503
10/22/17 10:45 PM
10/22/17 10:45 PM
BradH Offline OP
BradH  Offline OP
Thanks. grin
Funny you mention the small block thing. Since I seem to be one of the few BB people who still run a stock stroke, I've been thinking of my engine as more of a stroker SB... with a really heavy bob weight. wink
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391509
10/22/17 10:53 PM
10/22/17 10:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
What did i win?
Stopping in Hazleton for some Senapes Pitza would have been a nice prize
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391516
10/22/17 11:01 PM
10/22/17 11:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
And not just a little rich either........some were way way rich with light loads simulating highway driving.
Under those conditions, the main circuit is already flowing plenty of fuel,........and you're not going to lean out the mixture by 3.5 points by tweaking an air bleed.
All the carbs had a tendency to richen up throughout the run(both the turbines and O2 agreed).......some worse than others.
And, as I recall, it seemed to have the flattest fuel curve.
Re: All the specs to start your dyno #s guesses! 8^) [Re: sixpackgut] #2391517
10/22/17 11:01 PM
10/22/17 11:01 PM
BradH Offline OP
BradH  Offline OP
Originally Posted By sixpackgut
What did i win?
haha
I haven't done the reviews of all the predictions to see who is closest to the two categories... but yours looked pretty good when you first posted them.
I'm still typing this stuff on my phone while on the drive home. I'll try to figure out who gets the Summit gift card(s) as soon as possible, but it may not be until tomorrow.
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391520
10/22/17 11:08 PM
10/22/17 11:08 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
this might be why some of the carb tuners talk about all the newer bodies such as QFT and the variants need transfer slot restrictors in the bodies?
Re: All the specs to start your dyno #s guesses! 8^) [Re: BradH] #2391521
10/22/17 11:10 PM
10/22/17 11:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'm sure that would help with the part throttle.
Re: All the specs to start your dyno #s guesses! 8^) [Re: krautrock] #2391523
10/22/17 11:13 PM
10/22/17 11:13 PM
BradH Offline OP
BradH  Offline OP
Transfer slot restrictions alone won't correct this type of driveability issue, although they may be one the things changed as part of the fix.
Re: All the specs to start your dyno #s guesses! 8^) [Re: fast68plymouth] #2391524
10/22/17 11:15 PM
10/22/17 11:15 PM
BradH Offline OP
BradH  Offline OP
Dude! Still about 30 minutes from home... at least we're in the right state now.
