cam degreeing question #239117
02/28/09 07:34 PM
02/28/09 07:34 PM
California
70SportSatellite Offline OP
super street
super street
California
Ok, I installed the cam and used the .050 method on the intake. the cam card says it should be 2 before and i get 6 before. it says 38 after and i'm closing at 30. I used the lobe center method and it reads 108 which is what the card says. run it? thanks.
Re: cam degreeing question [Re: 70SportSatellite] #239118
02/28/09 07:43 PM
02/28/09 07:43 PM
UK
602heavy Offline
602heavy  Offline
UK
Think i'd be checking with the cam company , those #s don't add up . you used a solid lifter right?
Re: cam degreeing question [Re: 602heavy] #239119
02/28/09 08:50 PM
02/28/09 08:50 PM
California
super street
super street
California
used a solid lifter and checked it over and over. I dont think im making a mistake but its possible. I made sure the wheel was zero and rotated until i saw .050 at the lift side of intake and read the wheel then .050 at the bottom.
then i checked it .020 before max lift and .020 after and added those 2 and divided by 2 to get 108.
Re: cam degreeing question [Re: 70SportSatellite] #239120
02/28/09 09:37 PM
02/28/09 09:37 PM
you took a degree wheel reading @.050" before max lift & another one @.050 after max lift,added the two together, divided them by 2 & got 108. You're perfect.
