Firewall grommet hole for tachometer
#2391055
10/22/17 02:28 AM
10/22/17 02:28 AM
340clone
Can anyone post a pic of the correct location for the firewall grommet hole for a tachometer on a '72-'74 B-body? (Or describe the exact location)
I know that '71 uses an existing connector on the firewall harness plug, but later years are supposed to have a dimple somewhere on the driver side firewall that marks the spot.
Thanks!
Re: Firewall grommet hole for tachometer
[Re: 340clone]
#2392129
10/24/17 12:37 AM
10/24/17 12:37 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Actually as far I recall, 74s also uses the only cavity left empty on NSS harness plug. 72/73 uses the grommet. There are couple of threads with this info at FBBO board, just can't post the link right now.
[Re: 340clone]
#2393332
10/26/17 01:14 PM
10/26/17 01:14 PM
340clone
Thanks for all of the photos! I was able to reference a '73 Charger with a factory tach and the hole with plug was in between the M/C backing plate and the harness block. On my '74, the harness plug that goes through there contains all of the A/C wiring that goes out to the engine bay. Must have been a change after '73. Does any one happen to have access to a '74 that may have had a factory tach? Thanks!
[Re: 71birdJ68]
#2393538
10/26/17 09:51 PM
10/26/17 09:51 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Those aren't 71 B bodies. Yes sir, I stand corrected. Had to look again. I got the pics off a 71 B Body site.
Abe Lincoln
[Re: dart4forte]
#2394188
10/28/17 12:53 PM
10/28/17 12:53 PM
NachoRT74
Valencia, España
imposible... thats A or earlier B, never 71 and later B
[Re: 340clone]
#2394194
10/28/17 01:00 PM
10/28/17 01:00 PM
NachoRT74
Valencia, España
Thanks for all of the photos! I was able to reference a '73 Charger with a factory tach and the hole with plug was in between the M/C backing plate and the harness block. On my '74, the harness plug that goes through there contains all of the A/C wiring that goes out to the engine bay. Must have been a change after '73. Does any one happen to have access to a '74 that may have had a factory tach? Thanks! 74 bulkhead disposition, cavity 4, NSS harness BH plug As mentioned, just 72/73 are with grommet. 71s uses the engine harness plug cavity left, since AC uses the two left free on NSS harness plug ( these doesn't get the NSS ground into the cab like post 72 cars )
