Firewall grommet hole for tachometer #2391055
10/22/17 02:28 AM
10/22/17 02:28 AM
3
340clone Offline OP
340clone  Offline OP
Can anyone post a pic of the correct location for the firewall grommet hole for a tachometer on a '72-'74 B-body? (Or describe the exact location)
I know that '71 uses an existing connector on the firewall harness plug, but later years are supposed to have a dimple somewhere on the driver side firewall that marks the spot.
Thanks!
Re: Firewall grommet hole for tachometer [Re: 340clone] #2392129
10/24/17 12:37 AM
10/24/17 12:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Actually as far I recall, 74s also uses the only cavity left empty on NSS harness plug. 72/73 uses the grommet. There are couple of threads with this info at FBBO board, just can't post the link right now.
Re: Firewall grommet hole for tachometer [Re: NachoRT74] #2392177
10/24/17 02:37 AM
10/24/17 02:37 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Here ya go
Abe Lincoln
Re: Firewall grommet hole for tachometer [Re: 340clone] #2393228
10/26/17 02:38 AM
10/26/17 02:38 AM
3
340clone Offline OP
340clone  Offline OP
Thank you! What year cars are the firewall pics from?
Re: Firewall grommet hole for tachometer [Re: 340clone] #2393232
10/26/17 03:06 AM
10/26/17 03:06 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
71 Road Runners
Abe Lincoln
Re: Firewall grommet hole for tachometer [Re: dart4forte] #2393243
10/26/17 08:11 AM
10/26/17 08:11 AM
Conway, SC
T2R9 Online confused
T2R9  Online Confused
Conway, SC
Here is a picture of my 71 Road Runner engine compartment. You can see the plug just to the right of the master cylinder next to the bottom of the clutch reinforcement plate.
Re: Firewall grommet hole for tachometer [Re: 340clone] #2393332
10/26/17 01:14 PM
10/26/17 01:14 PM
3
340clone Offline OP
340clone  Offline OP
Thanks for all of the photos! I was able to reference a '73 Charger with a factory tach and the hole with plug was in between the M/C backing plate and the harness block. On my '74, the harness plug that goes through there contains all of the A/C wiring that goes out to the engine bay. Must have been a change after '73. Does any one happen to have access to a '74 that may have had a factory tach? Thanks!
Re: Firewall grommet hole for tachometer [Re: dart4forte] #2393391
10/26/17 03:16 PM
10/26/17 03:16 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Those aren't 71 B bodies.
Re: Firewall grommet hole for tachometer [Re: 71birdJ68] #2393538
10/26/17 09:51 PM
10/26/17 09:51 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Yes sir, I stand corrected. Had to look again. I got the pics off a 71 B Body site.
Abe Lincoln
Re: Firewall grommet hole for tachometer [Re: dart4forte] #2393546
10/26/17 10:12 PM
10/26/17 10:12 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Just didn't want to confuse the OP.
Re: Firewall grommet hole for tachometer [Re: dart4forte] #2394188
10/28/17 12:53 PM
10/28/17 12:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted By dart4forte
71 Road Runners
imposible... thats A or earlier B, never 71 and later B
Re: Firewall grommet hole for tachometer [Re: NachoRT74] #2394189
10/28/17 12:55 PM
10/28/17 12:55 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
We got it straightened out. Actually an E body would be the same I would think.
Re: Firewall grommet hole for tachometer [Re: 340clone] #2394194
10/28/17 01:00 PM
10/28/17 01:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
74 bulkhead disposition, cavity 4, NSS harness BH plug
As mentioned, just 72/73 are with grommet. 71s uses the engine harness plug cavity left, since AC uses the two left free on NSS harness plug ( these doesn't get the NSS ground into the cab like post 72 cars )
Re: Firewall grommet hole for tachometer [Re: 340clone] #2399720
11/07/17 12:13 AM
11/07/17 12:13 AM
3
340clone Offline OP
340clone  Offline OP
Well the mystery is solved! I had already bought the grommet type, thinking it was for a '74 so I will just drill a hole for it and make it look as factory as possible.
