Re: 1971 roadrunner door locks
[Re: EV2 340]
#2390985
10/21/17 10:17 PM
10/21/17 10:17 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
There is a small plastic push in clip that holds the rod in the hole of the mach. E body uses the same clip and nobody makes it. You can use a small metal rod chip. The end that goes into the cylinder does not use a clip.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2391001
10/21/17 11:05 PM
10/21/17 11:05 PM
Posts: 34 ILLINOIS
EV2 340
ILLINOIS
There is a small plastic push in clip that holds the rod in the hole of the mach. E body uses the same clip and nobody makes it. You can use a small metal rod chip. The end that goes into the cylinder does not use a clip. YES!! Thank you! Now, just one more question, how do i get that rod out of the white plastic part?? Do i just pull it out, and conversely, when i put it back do I just push it into the white plastic hole on the Mech...
[Re: EV2 340]
#2391008
10/21/17 11:27 PM
10/21/17 11:27 PM
moparmarks
I use a long screw driver and reach in there and pry the rod out of the clip. Then yes, just push it back in. Can be kind of a pain in butt. So from the start. Install lock cylinder into door Install rod into cylinder. Push other end of rod into clip.
[Re: moparmarks]
#2391027
10/22/17 12:35 AM
10/22/17 12:35 AM
RapidRobert
yes, use the right blade width screwdriver (a wide one) to pry it out of the plastic bushing.
