1971 roadrunner door locks #2390972
10/21/17 09:39 PM
10/21/17 09:39 PM
ILLINOIS
E
EV2 340 Offline OP
EV2 340  Offline OP
E
ILLINOIS
Can someone please tell me how the end of this rod connects into the door mechanism, i'm trying to get mine out but can't figure out how it comes out, does this rod go into the mechanism last when you are installing the door locks?? I can't figure it out..
Re: 1971 roadrunner door locks [Re: EV2 340] #2390976
10/21/17 09:42 PM
10/21/17 09:42 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 1971 roadrunner door locks [Re: amxautox] #2390982
10/21/17 10:10 PM
10/21/17 10:10 PM
ILLINOIS
E
EV2 340 Offline OP
EV2 340  Offline OP
E
ILLINOIS
yes thank you i read it but it wasnt that clear to me, im just trying to ask it in a more understandable way, maybe its just not clear to me, trying to find out hoe the rod lever connects to the door mech. its impossible to pu on the c clip to the back of the lock barrel when its already in the door, so i though maybe i can take the rod out of the door mech, build the whole assembly outside of the door, slip it back in thru the lock hole then hook the rod back up to the door mech, i just cant figure out how the rod attaches to the door mech inside the door..
Re: 1971 roadrunner door locks [Re: EV2 340] #2390985
10/21/17 10:17 PM
10/21/17 10:17 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
There is a small plastic push in clip that holds the rod in the hole of the mach. E body uses the same clip and nobody makes it. You can use a small metal rod chip. The end that goes into the cylinder does not use a clip.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1971 roadrunner door locks [Re: moparmarks] #2391001
10/21/17 11:05 PM
10/21/17 11:05 PM
ILLINOIS
E
EV2 340 Offline OP
EV2 340  Offline OP
E
ILLINOIS
YES!! Thank you! Now, just one more question, how do i get that rod out of the white plastic part?? Do i just pull it out, and conversely, when i put it back do I just push it into the white plastic hole on the Mech...
Re: 1971 roadrunner door locks [Re: EV2 340] #2391008
10/21/17 11:27 PM
10/21/17 11:27 PM
moparmarks Offline
moparmarks  Offline
I use a long screw driver and reach in there and pry the rod out of the clip. Then yes, just push it back in. Can be kind of a pain in butt.
So from the start.
Install lock cylinder into door
Install rod into cylinder.
Push other end of rod into clip.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 1971 roadrunner door locks [Re: moparmarks] #2391027
10/22/17 12:35 AM
10/22/17 12:35 AM
yes, use the right blade width screwdriver (a wide one) to pry it out of the plastic bushing.
