Page 6 of 6 1 2 3 4 5 6
Re: Best PCV valve? [Re: srunge55] #2389634
10/19/17 12:21 AM
10/19/17 12:21 AM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I need to do some more tuning on mine because it seems to be burning a little oil shruggy I might need to put a separator on it because my engine never had any blue smoke before. I need to go over the instructions again.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: fourgearsavoy] #2390085
10/19/17 11:26 PM
10/19/17 11:26 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Gus,
I wonder about the grommet. The ME folks comment about the air velocity being pulled by the PCV inlet, and although that small slot helps a lot with oil splash, I have to believe that the air velocity thru that slot is pretty high. The slot may help strip the oil from the air stream????
On my car, I added 1/4" spacers between the baffle and valve cover. I haven't driven the car enough yet, but my initial check for accumulation at the vapor separator did not show anything.
Re: Best PCV valve? [Re: UCUDANT] #2390304
10/20/17 02:37 PM
10/20/17 02:37 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
The NAPA grommet is a little tight around the PCV body, and in the hole of my generic fleabay fabbed AL rocker boxes, but fits. Hopefully no more weeping around the grommet.OD We'll see in the spring when this thing is back on the road.
I was using a Mr. Gasket grommet and a Fram 4.6 Mustang valve.
Re: Best PCV valve? [Re: BcudaChris] #2390768
10/21/17 12:25 PM
10/21/17 12:25 PM
moparx Offline
moparx  Offline
can anyone recommend an oil vapor separator ?
beer
Re: Best PCV valve? [Re: UCUDANT] #2390787
10/21/17 01:04 PM
10/21/17 01:04 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I bought a Mustang separator that's small and well made with a needle valve drain, it's at my son's house now.
I'll try to see if he can relay the #s to me and I'll update....stay tuned, Joe
"Steeda" Oil separator Kit, #555-3710
Re: Best PCV valve? [Re: UCUDANT] #2390897
10/21/17 04:54 PM
10/21/17 04:54 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I don't have MP valve covers so with a 1" hole and a thinner retaining lip the Napa grommet I showed previously works in my application
Re: Best PCV valve? [Re: jlatessa] #2391121
10/22/17 11:26 AM
10/22/17 11:26 AM
moparx Offline
moparx  Offline
THANKS JOE ! i'll check that out ! small is what my choice is after, but well made is first on the list. sounds like this may be both requests in one package.
beer
Re: Best PCV valve? [Re: moparx] #2391944
10/23/17 05:57 PM
10/23/17 05:57 PM
BcudaChris Offline
BcudaChris  Offline
I've used Steeda stuff for years on my Brand X ride, I used to live near their operation in Pompano Bch, FL. Good stuff and great service. I haven't used an oil separator as my SOHC 4.6 doesn't use a drop between changes, but if it matches the quality of the rest of their stuff, you won't be disappointed.
Re: Best PCV valve? [Re: BcudaChris] #2391950
10/23/17 06:03 PM
10/23/17 06:03 PM
Rittman Ohio
Rittman Ohio
That Steeda unit looks just like the water separator on my air compressor line work
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: BcudaChris] #2392850
10/25/17 12:30 PM
10/25/17 12:30 PM
moparx Offline
moparx  Offline
good to hear ! just planning my installation[s], and the separator[s] will be just insurance to insure a clean supply of air to the carb/intake. thanks again !
beer
Re: Best PCV valve? [Re: moparx] #2393751
10/27/17 11:37 AM
10/27/17 11:37 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I've got an update, it looks like the P.O. dropped the ball just before the finish line. I've been working with Barbara and she's gone above and beyond to get a replacement, even refusing my offer to pay for UPS shipping to my work address. I don't get P.O. delivery @ the worksite and I wanted delivered in my hot little hands.
