Small block help #2389521
10/18/17 09:25 PM
10/18/17 09:25 PM
usa,pa
jkwedge540 Offline OP
usa,pa
Looking to build a small block pro charger motor. What block and heads would you use. 59 or 48 lifter bores. First time messing with a small block. Thanks
Re: Small block help [Re: jkwedge540] #2389562
10/18/17 10:28 PM
10/18/17 10:28 PM
P
Porter67 Offline
Porter67  Offline
P
Let me be the first to try to sway you from spending way too much money with way mo-better options.
Re: Small block help [Re: jkwedge540] #2389582
10/18/17 11:00 PM
10/18/17 11:00 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
The hardest part is going to be able to find a block to get started with I would be looking for a tall deck 48 degree and there hard to find Not sure if the RItter block is straightened out yet with its troubles from the past
Re: Small block help [Re: jkwedge540] #2389617
10/18/17 11:54 PM
10/18/17 11:54 PM
Az
Crizila Offline
Crizila  Offline
Az
If you are looking to stay with a stock block, look for an E58 coded motor. They came in lots of HD optioned cars - late Magnums, 300's, Squads, Taxi's, some trucks. Magnum blocks would be another option. Don't know what HP you are shooting for - assume 700 max with a D1SC? Sonic testing the cyl. walls for sure. Girdle, forged rotating assembly for sure also. Rosary beads hanging from the rear view mirror - - - - . smile
Fastest 300
Re: Small block help [Re: jkwedge540] #2389822
10/19/17 01:46 PM
10/19/17 01:46 PM
K
Kiddart Offline
Kiddart  Offline
K
if you are looking go Gen 3, its probly better way and more cost effective. just my two cents. Plus they have kits all over the place to procharge or blower style.
Thank you
Kiddart
Re: Small block help [Re: Kiddart] #2389980
10/19/17 07:39 PM
10/19/17 07:39 PM
usa,pa
usa,pa
I want a after market block.
Re: Small block help [Re: jkwedge540] #2390039
10/19/17 09:57 PM
10/19/17 09:57 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
good luck finding an r3 tall deck short deck r3 s seem more plentiful used but tough to squeeze a decent ring pack in a short piston to handle a power adder.ritter blocks have come a long way since their introduction,i would go thru ryan Johnson because he is familiar with what needs done to those blocks.he wont have you buying parts you don't really need.really good guy and extremely fair price wise.
Re: Small block help [Re: webemopes] #2390073
10/19/17 11:06 PM
10/19/17 11:06 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
How big are you wanting to do? That is going to determine the deck height you can go with. R3 blocks are around, but it can be slim pickings.
Gen III or R5/P7 ,may be a better option.
Alan Jones
Re: Small block help [Re: LA360] #2390239
10/20/17 11:41 AM
10/20/17 11:41 AM
Sioux Falls, SD
MGC340 Offline
MGC340  Offline
Sioux Falls, SD
I have a tall deck R1 48' that I'm selling. I'd make someone a good deal on it. I have new cam bearings as well. It's 4.030 bore and 4 bolt mains. Pm me if anyone is interested
Re: Small block help [Re: MGC340] #2390473
10/20/17 08:34 PM
10/20/17 08:34 PM
usa,pa
usa,pa
Want to make it a 440 cid. Not sure what’s the best way to go.
Re: Small block help [Re: jkwedge540] #2390490
10/20/17 09:00 PM
10/20/17 09:00 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
How much power do you want to make? I ran a 59 degree r3 block with Indy 360-1 heads, 9:1 compression, and 408 cubes. Makes around 1300 at the flywheel.
Re: Small block help [Re: jkwedge540] #2390543
10/20/17 10:33 PM
10/20/17 10:33 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Just remember that the 59 degree blocks are not very roller cam friendly beacuse of the pushrod angle's... too much monkey motion. Offset valves/and rockers help quite a bit.
Re: Small block help [Re: jkwedge540] #2390629
10/21/17 12:59 AM
10/21/17 12:59 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
You should seriously consider the Gen 3 Hemi instead of a small block. Unfortunately the Small Block is pretty much in extinction with lack of parts. Rob Goss's Challenger is the benchmark for a procharged Gen 3. Good aftermarket Blocks an Heads readily available.
Re: Small block help [Re: Medlock51] #2390635
10/21/17 01:29 AM
10/21/17 01:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Not all roller lifters will work but there is some that work just fine. I have about 2000-2500 miles on a solid roller W2 headed 59* R1 block. I am using some mopar performance/crane roller lifters that clear the R1, comp also makes a lifter with the link bar moved that would work with the 59* R blocks. I think the comp lifter is an 8043-16 but not positive.
Going with a G3 would not be a bad idea though.
68 Barracuda Formula S 340
Re: Small block help [Re: Bad340fish] #2390666
10/21/17 03:09 AM
10/21/17 03:09 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I think everyone should step up to gen 3’s too. PS, when you are ready to sell your old school stuff please let me know.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block help [Re: pittsburghracer] #2390717
10/21/17 10:31 AM
10/21/17 10:31 AM
8
80arrow Offline
80arrow  Offline
I agree.... up. Let me know also, when you want to get rid of your outdated stuff
Re: Small block help [Re: Medlock51] #2390719
10/21/17 10:33 AM
10/21/17 10:33 AM
8
80arrow Offline
80arrow  Offline
My roller lifters have been just fine? You don't need a radical cam with boost, mines very mild, it'll idle at 900 rpm pretty easily
Re: Small block help [Re: jkwedge540] #2390839
10/21/17 02:37 PM
10/21/17 02:37 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
any idea what rob goss has invested in time and money on developing his gen 3 program,he was going thru factory blocks at about 4 to 6 passes apiece.he has since gone to his billet blockwhich I'm sure is not a bargain piece lol.the builder probably doesn't need to make the power rob is making so I understand a production block may work for him.im old school and if you want efi and the whole works gen 3 is ok I guess but blow thru distributor engine I would still stay smallblock
Re: Small block help [Re: jkwedge540] #2390871
10/21/17 03:33 PM
10/21/17 03:33 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yes I don't think the original poster is will be making anywhere near the power or using anywhere near the boost that Rob does.
While I will continue to build "old stuff" using LA R blocks. If I did not have any of it I would not waste any time going to a Gen III hemi.
Bill
Re: Small block help [Re: 340Cuda] #2391064
10/22/17 02:57 AM
10/22/17 02:57 AM
LA360 Offline
LA360  Offline
Rob Goss is running a solid cast block with Billet heads. The same block is available with water jackets. They certainly broke a lot of parts working out what worked or not.
There are many options here really, a 9.2" or 9.6" deck R3 with a W series head
A Ritter or EEI block with P7 heads
A Gen III Hemi, factory block and heads will get it done. You can can spring for a pair of Thitek heads and Aluminium block from BES
Alan Jones
