Do you use a pcv valve? #2389423
10/18/17 05:50 PM
10/18/17 05:50 PM
Tacoma, Washington USA
Adam71Charger Offline OP
We're firing up my 440 at the machine shop in days. It's got ported sidewinder heads and the racer Brown st21 can. I was going to use a breather but I'm wondering if I should also use a pcv or pcv/catch can?
Re: Do you use a pcv valve? [Re: Adam71Charger] #2389437
10/18/17 06:14 PM
10/18/17 06:14 PM
AndyF Offline
AndyF  Offline
You should use a PCV on a street car. On a race car you can use breathers on each valve cover or some sort of evac system.
Re: Do you use a pcv valve? [Re: Adam71Charger] #2389467
10/18/17 07:32 PM
10/18/17 07:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I use breathers on my street car. I also change the oil & filter at 1k, without pcv ,moisture can build up, so far I have not seen any when I adjust the valves.
Re: Do you use a pcv valve? [Re: CSK] #2389507
10/18/17 09:04 PM
10/18/17 09:04 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I use two breather on my street and strip car too...
Pcv reintroduce oil fumes into the engine and I think it's not the best octane booster..
I agree pcv is good for everyday car
Re: Do you use a pcv valve? [Re: AndyF] #2389530
10/18/17 09:35 PM
10/18/17 09:35 PM
iagree
I do, always up Moisture will condensate in your motor when sitting over night, the heat from the motor oil warming up the oil will help turn that moisture into steam (hot air rises)which the PCV will suck out removing it from the oil helping keep the oil in better, useable condition up
Re: Do you use a pcv valve? [Re: Adam71Charger] #2389640
10/19/17 12:28 AM
10/19/17 12:28 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Pretty much every engine up to the early 60s emissions era did not use them. Just had a pipe that turned down from a stand pipe on the valve cover, the old push on covers, vented to air. Either way engine must be vented. A good barometer on how the engine is lasting, no blow by, good, a lot, time for overhaul.
Re: Do you use a pcv valve? [Re: Adam71Charger] #2389651
10/19/17 12:40 AM
10/19/17 12:40 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I always run them, my 434" small block made three more hp on the dyno with it hooked up.
Re: Do you use a pcv valve? [Re: cudaman1969] #2389670
10/19/17 01:11 AM
10/19/17 01:11 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yes, a good tell tale of engine condition. Remember back then how at red lights the air would fill with blow by from some of the high mileage (over 50,000) cars waiting for green?
Re: Do you use a pcv valve? [Re: cudaman1969] #2389681
10/19/17 01:50 AM
10/19/17 01:50 AM
I was working in service stations in the early 1960s when CA mandated PCV, I think most of the standard Mopar passenger cars had them stock from either 1962 or 1963 shruggy scope
The road draft tubes that hung down under the engines where relying on the passing air to help suck the fumes out of the motor, didn't work well at slow speed or when stop either shruggy
As far as the engine blow by hurting the engine if it is bad enough to see it is time to fix it up twocents
Water of any type in the engine oil or any other part(tranny, rear end) being lube is not good tsk down
Re: Do you use a pcv valve? [Re: Adam71Charger] #2390315
10/20/17 03:16 PM
10/20/17 03:16 PM
Does a pcv need a certain amount of vacuum to work? Did anyone have issues with a low vacuum cam?
Re: Do you use a pcv valve? [Re: Adam71Charger] #2390354
10/20/17 05:01 PM
10/20/17 05:01 PM
The better PCV do need a minimum, how much I don't, vacuum to keep them open. The cheaper ones will stay open most of the time when the motor is running shruggy
All of them I've seen and cleaned have a check ball and spring to close the ball when the motor is not running, not all of them will seal up when not held open by vacuum shruggy
Re: Do you use a pcv valve? [Re: Cab_Burge] #2390659
10/21/17 02:38 AM
10/21/17 02:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
iagree
Cab is right and its one of the reasons I prefer to run a PCV valve on my street car. Ron
Re: Do you use a pcv valve? [Re: CSK] #2390754
10/21/17 12:01 PM
10/21/17 12:01 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have been running dual breathers for 15 years with no problems. Never had any water in oil or condensation in valve covers when I have adjusted valves. Only time I could see it help if you start and run your car often for short periods of time and don't let it get warmed up. twocents
The only Carbs I care about are under the hood!
Re: Do you use a pcv valve? [Re: Adam71Charger] #2390816
10/21/17 01:58 PM
10/21/17 01:58 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Put a road tube on it.
Re: Do you use a pcv valve? [Re: Azzkikrcuda] #2390829
10/21/17 02:13 PM
10/21/17 02:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That is true as short runs without letting the eng warm up is not good. Many run breathers and if you run the eng long enough all the time you may be ok but running a PCV valve setup will help make it better even on short runs and it has not hurt my performance one bit. I like it for the added insurance against moisture buildup in the eng and getting the blowby gasses out of the crankcase faster. Ron
Re: Do you use a pcv valve? [Re: 383man] #2391497
10/22/17 10:40 PM
10/22/17 10:40 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
So a pcv valve on one side and a breather on the other side would be a good set up for the street?
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: Do you use a pcv valve? [Re: nasty68] #2392587
10/24/17 10:12 PM
10/24/17 10:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes. Ron
Re: Do you use a pcv valve? [Re: 383man] #2392962
10/25/17 04:37 PM
10/25/17 04:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree up
Re: Do you use a pcv valve? [Re: Adam71Charger] #2393011
10/25/17 06:40 PM
10/25/17 06:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run 2 breathers on my 440 The M1 and Dominator have no provisions for vacuum.Been like that for at least 15 years My son also ran 2 breathers on the 62 300 when he had it.Never a problem with it either and it had the OE motor.We just replace the draft tube when he put the cam in and drove thousands of miles.Rocky
Chrysler Firepower
