Re: 727 explosion at Milan last night....
[Re: John_Kunkel]
#2390469
10/20/17 08:26 PM
10/20/17 08:26 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A local racer recently lost a sprag which wiped out the case and rear support. Disassembly found other distressed parts. I gave him a list of the minimum parts I would replace but he won't spend the money.
Well then he's asking for it. People have been blowing these things up for 50 years, at least. If you haven't gotten the memo by now, it's hard to feel bad for you when you shell one.
[Re: John_Kunkel]
#2390470
10/20/17 08:27 PM
10/20/17 08:27 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Yikes, would be a good time to list the parts needed to prevent this
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: dustergirl340]
#2390478
10/20/17 08:41 PM
10/20/17 08:41 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Low band apply valve body. Billet steel drum. Bolt in sprag.
At least I hope that will, that's what I have.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2390540
10/20/17 10:31 PM
10/20/17 10:31 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i went with aluminum drum to prevent this!
Hell Hath No Fury Like Mine
[Re: Stroker Scamp]
#2390562
10/20/17 10:53 PM
10/20/17 10:53 PM
Posts: 3,426 Dandridge TN
Dabee
Dandridge TN
Yikes, would be a good time to list the parts needed to prevent this Im going to stir the pot. Build a power glide using all the correct race parts. Problem solved.
[Re: Dabee]
#2390573
10/20/17 11:13 PM
10/20/17 11:13 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yikes, would be a good time to list the parts needed to prevent this Im going to stir the pot. Build a power glide using all the correct race parts. Problem solved. That was my choice. I lost some ET but its way more consistent, cheaper, more options, and safer. I've since recovered most of the lost ET so its a win win.
[Re: dustergirl340]
#2390597
10/21/17 12:00 AM
10/21/17 12:00 AM
Adobedude
New Mexico
I NEED a three speed, and it's a three speed 727 that blew up...info to help those of us running a 727 would be appreciated. Thanks.
[Re: dustergirl340]
#2390599
10/21/17 12:01 AM
10/21/17 12:01 AM
Posts: 20,169 Park Forest, IL
slantzilla
Park Forest, IL
I saw a guy blow up a 727 in a 340 Barracuda dialed 13:70. Had a Cheetah with no LBA and no blanket. His trans builder had tried go talk him into a billet drum and a blanmet, but he claimed he couldn't afford it. When it blew up it broke his foot and he was off work over a month.
727 is no place to be "frugal", especially when good parts aren't that expensive.
[Re: Adobedude]
#2390603
10/21/17 12:08 AM
10/21/17 12:08 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The parts you mentioned are a good start. I replaced rollers and springs regularly as well. Anything happens to the rear, driveshaft, spin the tires hard or anything like that, get the trans out and look at the roller clutch. Put it in second before you even go into the water box.
[Re: dustergirl340]
#2390614
10/21/17 12:24 AM
10/21/17 12:24 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I am going to call the builder of the trans that's in my 10.0 street Barracuda and find out whats in it.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: CMcAllister]
#2390618
10/21/17 12:28 AM
10/21/17 12:28 AM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You brought up a very good point about spinning hard. With radials now becoming so popular they either bite, or they don't. My Friend picked up .20 on radials a few weeks ago BUT during our Halloween Race I don't know what happened but he spun like a mad man during one time trial. And our track is known for good traction. If it was a 727 instead of a powerglide major damage could have happened inside the transmission.
[Re: pittsburghracer]
#2390630
10/21/17 01:11 AM
10/21/17 01:11 AM
Posts: 184 Memphis,TN
J. Hammer
Memphis,TN
Had a friends 1965 Belvedere puke its 727 on the street earlier this year. Could have been worse.
#2390634
10/21/17 01:29 AM
10/21/17 01:29 AM
Posts: 4,254 Canada
WO23Coronet
Canada
You brought up a very good point about spinning hard. With radials now becoming so popular they either bite, or they don't. My Friend picked up .20 on radials a few weeks ago BUT during our Halloween Race I don't know what happened but he spun like a mad man during one time trial. And our track is known for good traction. If it was a 727 instead of a powerglide major damage could have happened inside the transmission. How hard was he spinning? I don’t have anything with a 727 in it now but you guys have me absolutely terrified. After reading this I wouldn’t want to do a burnout or burn rubber with one. I knew there were nono’s but I’d be really fun shy to have any fun lol
#2390692
10/21/17 06:27 AM
10/21/17 06:27 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
If it was a 727 instead of a powerglide major damage could have happened inside the transmission. Spin and shake will screw up ALL automatics. Every T/D and T/S guy I know has a spare glide or 400 or Lenco. Most Powerglide users I know have at least two others laying around. Buddy of mine running Super E back in the 90's went through at least two glides every race! Built right, used and maintained correctly, a 727 should handle any of our 6-900hp engines. I do have a picture of my buddy's '63 Belvedere that looks like it ran over a deer on the starting line. CSR shield barely dented the floor. There wasn't a piece bigger than your fist left. I'll try to find it and post it.
[Re: John_Kunkel]
#2390703
10/21/17 09:27 AM
10/21/17 09:27 AM
Posts: 1,322 Michigan
crlush
Sometimes an incident like this is the only way to make believers out of skeptics.
You should have posters made of all the 727 failures due to stock parts in high hp cars and hang them in your shop, I saved these pics on this thred and have some others i found.
