Sway bar size #2389979
10/19/17 07:31 PM
10/19/17 07:31 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I need to order some front sway bar bushings and see for a 1970 Cuda they have 7/8 or 15/16 sizes. How do you know what size to get? Mine was disassembled before i got it. It is a big block if that makes any difference. TIA
Re: Sway bar size [Re: gregok] #2389985
10/19/17 07:51 PM
10/19/17 07:51 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
My little white book says .88 for 1970-1974 E Body. 1970 T/A had .94. Sorry, thats the diameter of the sway bar.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Sway bar size [Re: 70sixpkrt] #2390052
10/19/17 10:27 PM
10/19/17 10:27 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
7/8" = .88" and 15/16"= .94". If the white book quoted above is correct you would need the 7/8" bushings but I would measure the bar just to make sure. A quick way to measure would be to slip a 7/8 & 15/16 open end wrench over the sway bar.
Re: Sway bar size [Re: Ply72rr] #2390108
10/20/17 12:13 AM
10/20/17 12:13 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I will give that a try. Thanks for the info guys.
Re: Sway bar size [Re: gregok] #2390559
10/20/17 10:51 PM
10/20/17 10:51 PM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Can you still buy the correct sway bar bushing for the bigger bar?
Re: Sway bar size [Re: gregok] #2390568
10/20/17 11:04 PM
10/20/17 11:04 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I think I saw them in a Year One catalogue. Probably other venders have them as well.
