Your thoughts on my oil pressure with this weight oil #2389866
10/19/17 03:41 PM
10/19/17 03:41 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
540 Hemi in a mostly street car that sees occasional 7,000RPM passes at the local 1/8th.
My hot oil pressure is high 20s at idle (900+/-) and maxes in the high 60s just after 3,000RPM. That is more pressure than I need, isn't it? Are most of you comfortable with 10+PSI at idle and 60PSI max?
I have been running VR-1 20/50 for years now with no issues. But VR-1 is only available in 20/50 and 10/30.
I am thinking about trying the 10/30 VR-1, but just want to make sure that I am not taking any undue risk doing it.
I would appreciate your thoughts and opinions on this.
work
Master, again and still
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389868
10/19/17 03:49 PM
10/19/17 03:49 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
how many miles on the motor?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Your thoughts on my oil pressure with this weight oil [Re: amxautox] #2389876
10/19/17 04:25 PM
10/19/17 04:25 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
1,200 miles +/-
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389893
10/19/17 04:52 PM
10/19/17 04:52 PM
P
Paul_Fancsali Offline
P
No noise then quit worrying about it the engine is fine
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389894
10/19/17 04:58 PM
10/19/17 04:58 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I was told you want to use 20-50 in the hemi's because the thicker oil will stay up in the top of the head longer to lubricate the intake rockers. I think the oil pressure you have is perfect.
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389900
10/19/17 05:05 PM
10/19/17 05:05 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The old 10lbs. per 1,000 rpm thing. Yours sounds about right. I wouldn't go with the 10w-30 though. The pressure will go down, especially at idle. Just make sure it's full and depending on the gauge, I think you are fine. The reason I mention the gauge is because a 100lb. gauge might read different from say a 150lb. gauge or a Racepak pressure sensor.
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389903
10/19/17 05:20 PM
10/19/17 05:20 PM
Kirkland, Washington
Pacnorthcuda Offline
Do you often start a REALLY cold motor (you are in Illinios)? Cold as in below say 35-40?
If so I would be very leary of 20w50. Your oil pressure numbers look like they will support 10w30 just fine. Try it.
An interesting test: pour some oil into a jar, put in freezer overnight. Then see how they pour.
I was amazed, years ago, at how thick Castrol GTX 20w50 was!
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389911
10/19/17 05:30 PM
10/19/17 05:30 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's only going from 10w to 20w. There is a difference but it's not like going from a 10w to a straight 40w. When I change the 15w-40 in my diesel it comes out like water. IMHO I would run synthetic oil in that beast.
Re: Your thoughts on my oil pressure with this weight oil [Re: Pacnorthcuda] #2389919
10/19/17 05:44 PM
10/19/17 05:44 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Valid points on the cold weather thing. I don't start it below maybe 50* or so. And I have an Accusump that I prime with to help.
So far, it's about even between 'leave it alone' vs 'try the 10/30'.
I've heard two conflicting rumors about Hemi oiling; one is that you want a heavier oil to cushion between the crank and the heavy recip assembly. Although mine is lighter than stock being Barton pieces. The second is that a lighter weight oil flows more, particularly over the valve springs, thereby cooling them better.
I don't have any issue leaving well enough alone (meaning staying with the 20/50) if that is what is best for this engine. But if there were any real advantages to going a lighter weight, then I would certainly do that.
If there were a 15/40 VR-1, I would be comfortable trying that as it's not as drastic a step as going to 10/30.
Here's another question; the oil pressure tops at about 68lbs just past 3,000RPM. So doesn't that mean that any volume after that is just bypassed back to the pan?
Wouldn't a lighter weight oil that doesn't by-pass until higher PRM be flowing more?
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389954
10/19/17 06:47 PM
10/19/17 06:47 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Try it and let us know what you find out! You certainly won't hurt anything. This is a street car with an occasional wide open blast right? The Accusump is great! Oil pressure before the engine turns a lick! Also extra capacity which is always good. up
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2389968
10/19/17 07:08 PM
10/19/17 07:08 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What are your bearing clearances?
What does Barton recommend?
How hot do you get this engine on the street? Do you hot lap it at the track?
Your pressure does not seem too high like some with 80 psi.
I don't go along with the thick oil group.
Re: Your thoughts on my oil pressure with this weight oil [Re: NANKET] #2389973
10/19/17 07:23 PM
10/19/17 07:23 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Frankly, I don't remember. We checked the clearances and balance before assembly. They were good.
He didn't want to get into oil since it always causes lengthy discussions.
It is steady at 180*.
Occasionally
Re: Your thoughts on my oil pressure with this weight oil [Re: Cuda340] #2390019
10/19/17 09:10 PM
10/19/17 09:10 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Me too!
Facts are stubborn things.
Re: Your thoughts on my oil pressure with this weight oil [Re: larrymopar360] #2390033
10/19/17 09:39 PM
10/19/17 09:39 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
10/30 Mobil 1. We use it in everything incuding SS Hemis
The little old lady from Pasadena is back!
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2390055
10/19/17 10:39 PM
10/19/17 10:39 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
For reference, I used to run 20-50 in myb383. Took forever for the pressure to come down enough that I felt comfortable driving.
Dropped to 10-30, better warm up, no difference in pressure.
Dropped to 5-30, Even better warm up and still no drop in hot pressure.
I've considered trying 0-20. It's just an oil change and if it doesn't work drain and refill.
I have a high volume pump and deep Moroso pan but only run 6 qts.
Angry white pureblood male
Re: Your thoughts on my oil pressure with this weight oil [Re: ruderunner] #2390119
10/20/17 12:32 AM
10/20/17 12:32 AM
Cab_Burge Online work
Cab_Burge  Online Work
I ran 5W20 WT standard non synthetic Valvoline that Wal Mart stocked in my old pump gas Duster, it would have right at 18 to 20 lbs at 850 RPM in gear with 180+ F oil temps., 30+ lbs at 1200 RPM and 65 lbs. above 3000 RPM with the same oil temps. That motor made 727 HP and 700 + Ft lbs. on pump Oregon 91 octane pump gas the last time I had it on a DTS engine dyno with that oil and oil temps. work I would shift the motor at or a little above 7000 RPM with 65 lbs. pressure, no problems with the bearings or any other parts in that motor, solid roller cam with full time oiling to the Harland Sharp roller rockers with a .040 restrictor to each side up 250 Lbs. pressure on the seats and 650 lbs. open pressures up
Lots of myths on oil and every other part found in our Hi Po motors, not every one agrees on any of them shruggy
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2390163
10/20/17 02:14 AM
10/20/17 02:14 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I'd be happy with those numbers and I would stay with the 20/50 mineral , what could possibly be achieved buy going to a thinner oil.
I always get heat into my engines before they get a beating.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Your thoughts on my oil pressure with this weight oil [Re: ozymaxwedge] #2390178
10/20/17 02:48 AM
10/20/17 02:48 AM
I would for sure try the thinner oil. I'd want the thinnest oil that maintains the psi I am OK with. I may be off base on this & I do not know Hemis but I don't think using a heavier oil cuz it stays up top later is valid, I'd want the thin oil continually flowing. Nascar goes with thinner oil for a reason.
Re: Your thoughts on my oil pressure with this weight oil [Re: ozymaxwedge] #2390193
10/20/17 05:09 AM
10/20/17 05:09 AM
I switch from straight 30wt oil to 5W20Wt oil do to seeing right at 8HP gain running the oil temps on the engine dyno testing from 130 F to 160 F shock I then tried 10W30WT and saw 3 HP difference going from 130 F to 170 F.
The next engine I tested was with 5W20WT and I saw no differences in HP going from 80F to 200 F oil temps on a roller cam bracket race motor work boogie
Oil does two things in our motors, it lubricates and cools the parts it touches up The sooner it is lubricating it is also cooling resulting in less wear and tear on our parts work
Re: Your thoughts on my oil pressure with this weight oil [Re: DaveRS23] #2390219
10/20/17 10:41 AM
10/20/17 10:41 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would try the thinner oil and see what your hot idle pressure looks like after. I think you'll be ok.
